Results 1 to 10 of 10
Thread: how much are you paying for shock?
    This may not be the right category for this question, but it looked correct to me.
    Just out of curiosity how much should those small bags of shock cost?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Re: how much are you paying for shock?
    A little over three bucks at Leslie's: Power Powder
    Now that I've answered your question....answer mine. Why would you want to use it?
    In the 45 lb bucket $62 or $1.38/lb.
    Quote Originally Posted by Richard320
    OK now that you have my attention, tell me my alternatives? I have only owned a pool for 1.5 years.
    I just bought 12 packs for about $90.00..... I know I can buy a different brand at Lowes for about 3.90 but I felt it did not work as well.
    Jul 2009
    Seattle, WA
    89
    Quote Originally Posted by gabagoo
    Sounds like you are buying "lithium hypochlorite", which is nice stuff in that it doesn't add any CYA or Calcium they way other "shocks" do. But unstabilized chlorine (aka bleach) is A LOT cheaper. check out pool school in the top right corner of the page.
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
    Dec 2009
    Central Massachusetts
    2,690
    Good old chlorox bleach works really well. BTW, shock is a process, not really a product. You can shock with any form of chlorine. Liquid is cheapest and doesnt add anything unwanted to your pool like CYA or calcium.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    NOTHING!..............You're 90 bucks worth of shock translates to about 60 gallons of bleach for me.
    Jul 2009
    Seattle, WA
    89
    To expand on Woody's point, a pound of lithium hypochlorite (you paid $7.50) will add 2.1 ppm of FC to my pool. The same increase could be achived with 2.75 cups of bleach (just under $2) or 12oz of the 48% Cal Hypo (about $2.25) I'm using because my CH is a touch low.
    22,553
    I pay about 11¢/KWH for my shock. Oh you didn't mean that did you. But, that's the only shock I buy.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Richard320's Avatar
    Jan 2010
    19,050
    As others have informed you, bleach works as good as anything and doesn't add any unwanted chemicals. I may be hypersensitive about this as I'm stuck with CYA 2-3X higher than it should be and CH slightly higher. All because the previous owner and his pool service used a floater with pucks and doubtless the occasional bag of shock.
    If you have low CH or low CYA, these other forms of chlorine are okay as long as you know what you're adding.
    Keep the pool clean and the FC above minimum and you may never have to shock your pool again.
