Results 1 to 11 of 11
Thread: Getting desperate, should I floc?
    Jul 2010
    Western MA
    18
    My filter has been running 24x7 for almost 3 weeks and I have to spray down my filter at least 3 times per day (and still can't keep up with it). I opened the pool late ( 7/1) and the algae had taken over. There is so much debris in the pool that it is taking forever to clear up. The filter is getting so clogged that it is impeding the flow of water ( that is why I'm cleaning 3 or more times a day). I'm beginning to think it might be easier to floc at this point and vacuum to waste, then top off pool as needed.
    Any suggestions?
    55k gallons, IG, Gunite w/pebble tec (dark grey), Sta Rite S8M150 50-124 fr, 2HP Sta Rite pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Getting desperate, should I floc?
    What color is the water and what is your chemistry looking like, particularly combined chlorine?
    Jul 2010
    Western MA
    18
    Yesterday AM the water was very cloudy, kind of grayish. I have black pebble tec. Then I swept the shallow end and stirred up some algae and it turn green (as expected). This AM it is back to being cloudy and grayish. The weird thing is, since I got my test kit (k-2006) on Saturday, the CC only reads about 1 ppm. It has been consistent. That seems strange to me. I figured between the shocking and sweeping, there should be some fluctuation in the CC. The FC reading changes as I'd expect. Last night I had a FC reading of 17 and this AM it was 14, so there is still OM that it is working on, but I would have thought the CC would have gone up.
    TA 120
    PH 7.2
    CYA 37 (there about)
    CH 180
    FC 14
    22,542
    You need to maintain shock level until you have 1ppm FC or less loss overnight and your CC's are .5ppm or less.
    And when I say maintain shock level that means testing and adding as often as once per hour.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Floc won't work if you still have live algae (sounds to me like you do.)
    Jul 2010
    Western MA
    18
    Does it make sense that the CC is staying at 1 ppm? Shouldn't there be some variability?
    11,969
    No, not necessarily. I know you are frustrated and losing POP, but hang in there, keep the shocking course. You'll get there.
    Jul 2010
    Western MA
    18
    I realize the floc want kill the algae, but wouldn't getting many of the suspended particles out of the way (to the bottom of the pool and vacuuming) help to better circulate the water, by reducing the need to clean the filter so frequently? I'm also thinking that if floc will help to get some of the suspended particles out of the way, I could see where residual pockets of algae remain. The deep end of the pool is just over 10 feet and I can't currently see a thing. It is difficult to be sure that I'm brushing everywhere. If I could see the bottom of the pool I'd have a better chance of get anything I'm missing. Don't get me wrong, I'm not **** bent on using floc, I'd rather not. I'm just willing to try anything that will get this pool clean. At this point, if I can't get it clean within the next week or so, I might as well close it. Given the short swimming season where I live (New England).
    11,969
    I hear you. I've just read one too many stories of folks who have used floc before the algae was dead and ended up with a problem worse than before.
    You could try turning the filter off, and letting it settle and then vac to waste sans the floc.
    This is a cart filter? You can vac to waste - do you have a "recirculate" setting that can bypass the filter?
    There isn't really any point to using floc before the algae is all dead. Floc can clear things up very quickly after the algae is all dead. If you have passed an overnight FC loss test, there is some value in trying floc.
    Jul 2010
    Western MA
    18
    Quote Originally Posted by frustratedpoolmom
    Yes, this is a cart. The only vacuum to waste option is (via the filter) is opening the drain on the filter. However, I have another pump that is connected to my returns and leaf trapper system that I can disconnect and use to vacuum the pool.
