Thread: Borate test
    Borate test
    Hi , I've been reading about borax ,
    Before I add any to my pool I need to get test strips, now I'm in south Africa and have not found any this side , the 1's I have found are all in the usa and none of the stores ship this side,
    Question is does anyone know of an online shop that will post to south Africa ?
    cheers
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Borate test
    Etie, welcome to TFP!
    I can't help with the supplier issue, but...one of the nice things about borates is that the level is not really critical. If you don't have a lot of water replacement (backwashing, rainwater overflow, etc; not evaporation), the borate levels will stay pretty stable. So, you could add ~50 ppm, and give it a little bump every time you replace some water, and you'll be fine.
