Thread: Tested my levels and CCs a bit high
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Question about dropping CCs.
    Yesterday we had an odd day. It poured like crazy at around 11am. Then it got extremely hot so my wife, our neighbors with kids, and our baby all went into the pool. Then later in the evening it poored like crazy again. So that was probably pretty tough on my pool's levels.
    This morning when I tested everything I had the following:
    FC - 3
    CC - 1
    CYA - 30
    PH 7.5
    I think this is the first time this summer Ive had more than .5 CCs when testing with the TF100.
    My wife is planning another big swim day with everyone except unfortunate me since somebody around here has to work in order to keep the heater on. So I dont want to dump tons of bleach in the pool and bring to shock levels.
    So added about 60oz of 12.5 bleach to bring the FC up to about 5.5 or so.
    My question is, can this alone bring my CCs down to .5 or 0?
    Or maybe just bringing up my FC again later tonight with another 60oz of 12.5 bleach to 8 or so....
    Or will I actually need to bring my pool to shock levels to lower the CCs?
    Thanks in advance!
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    22,539
    Re: Tested my levels and CCs a bit high
    I'd do just what you did and check them again this evening. A little sun and some high FC will no doubt help get rid of them. If it doesn't, then you can shock.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Sounds good as Bama said.
    I kind of did the same thing today...we got GOBS of rain over the last 2 days, the corn is tassling so there's crud in the air, and there's leaves etc I need to sweep out but don't have time this morning. I am maintaining a good FC level in the pool with the liquidator but today I added a jug of bleach to give more of a boost. Not really a shock dose, but just a little nudge up and still swimmable if we feel the need.
    That's what this method is all about. Adjusting based on trends and needs.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Mar 2010
    Spring, TX
    1,082
    When I get a test for CC, I usually just bump my FC up about 1-1.5 ppm and usually takes care of it.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Excellent thanks all!!!
