Thread: Dryrott???
    Jul 2010
    SE New Mexico
    2
    Dryrott???
    We purchased a Foxxx Pool liner in 2007 and had it installed. A week ago we noticed little holes in the top of the liner at the seam above the water line. We took picutres of it and sent it in to Foxxx to be covered under the warrenty. They told us it is dryrott caused by the harsh NM sun and suntan oils and lotions. Has anyone else had a problem like this or heard of this kind of an issue?
    Foxxx Vinyl 22x39 Reverse Kidney/Fiji Approx 22,500gal (I think)
    Hayward Super II-1Hp 230v single speed
    Purex Triton Tagelus 60 (sand)
    FC - Free Chlorine
    CC - Combined Chlorine
    pH -
    TA - Total Alkalinity
    CH - Calcium Hardness
    CYA - Cyanuric Acid (stabilizer)
    Borates - (if you are using borates)
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Dryrott???
    Yeah. I've seen it happen this year actually. It seems that scumline of oil and dirt greatly reduces the liners life span. Only seam seperations are typically covered under warranty. Keep you water line clean. Those scum balls work well as preventative maitenance. Try your home owners insurance, surprisingly 2 liners I did this year were covered fully for the home owner
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jul 2010
    SE New Mexico
    2
    Re: Dryrott???
    Thanks alot Kevin for the quick response. I mistakenly said 2007 but it was actually 2008. I dont know if that makes a difference though. We are dissappointed after investing nearly $4000 in costs and it only lasting 2 seasons. We were offered a new replacement liner from foxxx for a 20 mil at half price (discontinued patterns at about $1000) but don't know if we should be looking at a heavier mil to prevent this from ocurring again and being in the same situation 2yrs from now.
    Also. I am wondering if maybe the fit was too short that also added to the problem causing too much stress and stretch at the seam. I would imagine dry rot would be some what in lots of different areas not just at the hook seam only.
    FC - Free Chlorine
    pH -
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Dryrott???
    post a picture of the damage and we can probably give you a more accurate answer.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
