I'm getting more of these dots daily and some new ones are a little bigger (probably upto 2.5mm). Now I can see them on the bottom of the pool.
For the last couple of weeks I've been using "ultra" bleach from Aldi (6%. exp 10/10) and Austin's liquid chlorine from BJ's (12.5%. no exp date found). I have not been adding any other chemicals to my pool the last 2 weeks. Prior to that I used to shock with calcium based shock weekly with 2lb of shock (as I was told by the store), then with 1.5lb of shock (according to dosage listed on the container) and then every 10 days reducing the shock to 1-1.5lb,... and always had 3-6 tablets in dispenser, which kept my chlorine at 2-4ppm. I started noticing these dots when I started shocking every 10 days (instead of weekly), but it doesn't mean I didn't have thee dots when I was shocking weekly, I just started noticing them. I don't have any trees near the pool and I have not been brushing my pool weekly as I should have. I only brushed it when it had algae, at the end of may or so.
My CYA 30 (60 according to leslies)
FC 4.5-7 (at the end of the day I have about 4.5 and I add liquid chlorine to about 7).
CC .5
I don't have the rest of the tests handy, but I can list them here if they are important. According to leslies I don't have metals (or if I do, it's 1/2 of what's allowed, dont remember the actual number)
It seems like they have green and\or brown heads at first, but then when I brush the heads off with SS brush I have a black or dark brown spot left. It's hard to say if they are green or brown, it's more like a mix of both colors.
I think (and I hope) frustratedpoolmomis right and it is organic.
if it is organic, what should I do?
Should I try shocking the pool and if so, should I shock it with bleach to the shock level or should I go above the shock level or use something else instead of bleach?
Should I try rubbing with 3" chlorine tab? If so, can someone provide the steps so that I do it right. I used to rub a small piece of chlorine tablet against the dots for a few minutes but that worked on some black ones, but never worked on others, including the black ones that I have now.
Please advise.
