Thread: Hot tub light leaking
    Light in hot tub leaks, have drained hot tub and pulled light twice replacing gasket and bulb.
    It continues to leak. Any suggestions, pool and hot tub are less than two years old.
    20KG 16x32 In Ground Pool
    Pentair Wisperflow WFDS-24 on Low
    Hayward C17502 Cartridge Filter
    Hot Central Florida Sun
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Hot tub light leaking
    Sounds like the niche is leaking. With the light housing out, you should be able to do a dye test in the niche to find it. just squirt some food coloring near where you think it may be leaking, and watch to see if it gets pulled out.
