Results 1 to 9 of 9
Thread: How do you store your Muriatic Acid?
    Jun 2010
    Frisco, Texas
    18
    Was wondering how other people store their Muriatic Acid safely? I currently keep it in the box it came in up high on a shelf in my garage pushed to the back so that nobody but myself can get to it. I am curious to hear if there are better ways to store it.
    Thanks
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Re: How do you store your Muriatic Acid?
    Great question. I store mine in the garage but not on any shelves, just the floor, and it's in the sunlight when the garage door is open. (Probably not best but it's a space issue....)
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Muriatic acid is fairly easy to store. It can handle a wide temperature range. The only crucial step is to make completely sure that no muriatic acid ever comes in contact with any bleach. Store bleach and acid far enough apart that they won't get to each other even if both bottles leak. For total safety what you do is put the muriatic acid bottle in a bin/bucket, so any leaks are caught in the bin. The bin isn't really essential but it will protect you floor if the bottle ever leaked.
    I use an old kooler with a decent lid.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,202
    I keep mine in a plastic bucket. I had a jug leak a couple of years ago. I use the bucket to dilute the acid when I add it to the pool.
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Quote Originally Posted by sonflower
    If it leaks on the floor it will degrade the concrete.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Long time ago, before pool, we had muriatic acid on a metal shelf in the garage. Very hot here in TX. Over time, the acid escaped the jug and ate through the shelves. Thank goodness we noticed before it fell on to the car.
    Butterfly's Avatar
    South Carolina
    10,045
    We store MA outside, under the deck behind a brick pillar. It is exposed to outdoor temps, but not in direct sun.
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    I store mine in a Rubbermaid bench box. It's right next to my bleach but...it sits in a box by itself so that if the bottle(s) are compromised, the interior box will retain the materials and keep them separate.
