Results 1 to 9 of 9
Thread: New pool - startup chemical question
    Jun 2010
    Dripping Springs, TX
    125
    Hello,
    The plaster company did an acid wash on our Pebble-Tec yesterday morning, and we filled it with water.
    I put some sequestrant in the pool this morning and gave it a good brushing.
    I'm following the 'Acid Wash Opening' in the Pool School link, and just want to verify that I'm on the right track.
    I have a SWG, but I know not to turn that on for 30 days. TF-100 test kit should be here any day. I'm also loaded up on bleach, borax and baking soda - BBB all the way!
    Although the plaster company used muriatic acid to clean the Pebble-Tec, they did this before water went in it and vacuumed it all out.
    Do I need to add some muriatic acid today before brushing it again this evening? And if so, do I use the 3.5 gallons acid/10K gallons of water formula?
    Thank you!
    SF
    17K gallon IG freeform Pebble-Tec pool w/ raised spa/waterfall, Hayward 6020 DE filter, Tristar 1 HP circulation pump, Tristar 2.5 HP spa pump, Silencer 2hp blower, Aquarite SWG, Polaris 280 w/ booster pump, Hayward Universal H-Series 400K LPG heater, Ultrapure Ozonator 25, Aqualogic PS-8
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: New pool - startup chemical question
    You only need to add acid if the pool pH test is higher than 7.8 which is really important especially with new plaster. While you are waiting to get the TF-100 you might want to take a sample to the pool store if you have one and let them give you test results. Just because they added acid to acid wash does not give you an indication of what your current water chemistry is, you have to get a test done. Once you know the results then you can go to the pool calculator and determine what to put in.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    22,550
    First and foremost, you should follow the PB's instructions. It can and will affect your warranty if you don't.
    You only need muriatic acid to adjust your pH IF it's high enough to need it.
    The problem with the SWCG is not turning it on before 30 days it's adding the salt to the pool before 30 days.
    Apr 2010
    Fleming Island, FL
    431
    Not to contradict Bama, but I had a horrible pool builder. Not with building the pool but with communicating with me on what to do just after filling. I did not hear from him for about a week. During that week I was doing research and found out I was supposed to be brushing and maintaining the chemistry. He never told me any of this until I called him a week later and he said, "I didn't tell you to brush the pool and watch the pH?". I was a little upset. So just be cautious and ask lots of questions.
    Carlos
    Jun 2010
    125
    My TF-100 test kit just arrived in the mail and I'm holding it in my grubby little hands right now.
    I will test the water and post the results.
    Thank you very much for the quick responses everyone!
    SF
    Jun 2010
    125
    OK - here are the TF-100 readings:
    FC - 0.5
    CC - 1.5
    PH - 7.4
    TA - 190
    CH - 130
    CYA - 0
    As a reminder, this is a brand new pool with no chemicals added yet except for about 16 oz. of sequestrant.
    We filled with water hoses using city water - fairly hard water in this part of Texas.
    I think I need to add acid to lower TA, but this will also lower PH, so I'll need to aerate (spa waterfall) to bring PH back up.
    Just my guess from reading Pool School.
    Any and all recommendations appreciated!
    SF
    Jun 2010
    125
    Water is starting to look a little cloudy.
    Really interested to hear what the next steps are from a BBB perspective as I open my new pool.
    Test results repeated here:
    FC - 0.5
    CC - 1.5
    PH - 7.4
    TA - 190
    CH - 130
    CYA - 0
    Do these look normal for startup numbers? What's next?
    Thank you very much!
    SF
    You numbers look good.
    Once it has been 48 hours since the pebble tec was applied you can start using trichlor tablets to add chlorine and CYA slowly. Trichlor tablets work well during the first 30 days after fresh plaster is applied as you usually need all three things that they do (add chlorine, add CYA, and lower PH).
    Keep an eye on the PH and try to never let it get up to 8.0, ie lower the PH to 7.2 any time it gets to 7.8 or 7.9.
    Jun 2010
    125
    Thanks a ton Jason. It just so happens that I have an aerobic septic system, so I have some 3" Trichlor pucks sitting in my garage.
    I put 1 puck in each skimmer.
    I do have some granular CYA, but it sounds like you are saying I should not use it yet (?).
    I am still having a lot of rock work done and there is a lot of dust as they are sawing rocks right next to the pool. I think I'll
    be contending with this dust until this work is complete.
    Thanks again!
    SF
