Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Solar vs. wired Landscape Lighting
    Lehigh Valley, Pennsylvania
    71
    Looking for advantages/disadvantages when comparing wired and solar laow voltage lighting. I am looking to install lighting around my pool area. Also, any design ideas or particular lights anyone may have input on would be appreciated.
    Rob
    25K gal vinyl inground, 1HP Hayward Pump, Hayward DE 4820 Filter
    Feb 2008
    Denton, TX
    5,061
    Re: Solar vs. wired Landscape Lighting
    As far as durability and light output, my experience is that hardwired lighting wins hands down.
    Aug 2009
    SW Wisconsin
    518
    +1 for wired low voltage. I hav tried numerous solar lights..even fairly expensive ones..and they all "fail" to live up to the hype after a while. You want continuous, good quality lighting go with a wired system.
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    I have yet to see a solar light that actually provides any amount of light worth its price. They all tend to "glow" rather than actually giving off some serious light.
    I have done low voltage lighting all throughout the landscaping around the front of my home and it was a fairly easy DIY project. But I did learn that you really need to add up your total wattage (combined number of fixtures) per each circuit or you run the risk of there literally not being enough electricity left at the end of the wire run!! One problem I am having though is with the local wildlife chewing through my wires and shorting things out.
    However, when I put in the pool and hired a professional landscaper, I had them do the landscape lighting around the pool and they did everything hard-wired (put in an extra circuit in the breaker box by the pool equipment). I must say that watching them install the wire and fixtures, I realized it's really not that difficult and may consider replacing my low voltage stuff over time. I've noticed that you can buy all those fixtures right in your local Home Depot/Lowes.
    20'6" X 38'6" (609 sqft)
    22,500 gal gunite/plaster IGP
    DE filter, Jandy 2HP pump, Nature2 Sanitizer (removed cartridge!)
    Raypak 39.9K BTU gas heater
    2 ColorLogic lights, Maytronics Dolphin pool cleaner
    Dec 2009
    Central Massachusetts
    2,690
    Another vote for hard wired, hand down. Tim is right; the solar just glow and dont light anything.
    IMO though, the lights you get at a big box store just dont measure up. They wont last that long until you have to replace them. Get a good system with quality fixtures that will last. A good system will come with a multitap transformer that will allow multiple, longer runs. A good system will run a little higher, but you can always add on to the system.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    I agree that solar are not good.
    If you go with hardwired, you need to stay a certain distance from the pool, there are codes about that. I vote for low voltage, I think the outlet boxes for high voltage are just so ugly, near impossible to hide. You don't need that much power, it isn't an airport runway. You can get 20 watt, 35 watt or 50 watt low voltage bulbs and do all the lighting you need.
    Look at some used bookstores for a book by Ortho Books called How to Design and Install Outdoor Lighting. It is really old and has probably been updated, I probably got it at Home Depot. It will cover the basics of how to use different effects; up-lighting, down-lighting, silhouette, wall washing, when a beacon is appropriate, as well as voltage loss calculations and what gauge line to use.
    There are several online sources for fixtures and bulbs and I have found that my local irrigation parts store has a lot of decent products at close to the same price but that is probably not typical. Just get metal fixtures, not plastic and use the higher quality connectors, the grease filled kind, with caps. I found these at the irrigation store, not at big hardware stores.
    We did the lighting for the prior house and I had a lot of fun doing it. This house had been professionally done, probably more lights and higher wattage than I might have used but they did a nice job. Keeping that many bulbs maintained is a chore, I will point out. In the old house we put several lights up in trees for moonlight effects -- looks really nice but what a pain to get up there to change bulbs. As the years passed, the squirrels chewed some lines, the tree grew over and broke some lines and I worried more and more about my husband way up there on that tall ladder.
    The suggestions and comments to ignore the solar lights at the big box stores are right on. If you would like a quality designed system that will pretty much last at least 20 years then invest in a professional low voltage lighting system.
    If this is something you want to tackle yourself then send me an email and I would be glad to help you out.(ken@copperexpressions.com) If shopping for a low voltage lighting designer/contractor ensure you do your research on the company. There are lots of landscape companies that will install lighting but lack the knowledge and design experiences so taking the time to contact that perfect company will go along way. These reputable lighting contractors only install professional low voltage lighting systems and is their primary business.
    All products should be made from copper, brass or stainless steel as these will stand the test of time. Plastic will not stand the test of time from my experiences and this is something that I will not include into any of my designs.
    If you are thinking about energy savings they now have replacement MR16 bulbs that are LED. These replacement bulbs are compariable to a 20 watt bulb but be sure to purchase the warm white colour as these are in the same temperature colour as a halogen.
    Have fun and post back here to let us know how you have proceeded.
    Ken
    71
    Thanks Ken. Sent you a PM.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    1,672
    Depends on what you want. I purchased solar lights from Walmart and they seem to do the trick for us. Look at our pool build in the sig bar below and you will see pics. Hope this helps
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Dec 2009
    2,690
    I have a CAST system. The fixtures are solid bronze and should last forever. IMO, the solar lights dont light anything, they just glow.
    Feb 2012
    Tucson Arizona
    20
    It seems that since the last post on this thread two years ago, solar technology has come a long way. Costco (at least one of them in Tucson) right now has a killer deal on solar lights, an 8 pack for $30. They don't say how powerful each light is, but each one comes with a rechargeable AA NiCD battery. It looks like those batteries alone would cost maybe $15 dollars on their own.
    I was thinking about running a low voltage light system, tapping into the EasyTouch remote and relay system in the breaker panel, but at that price, seems like you can do no wrong with the solar. What do you guys think?
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    I use both low voltage and solar but most of my lighting is for visual effects around the pool. Spent the $30 and put them out there and see whether you like it. They're always handy to have for lighting. I use some light fixtures that go under my caps on the wall for the low voltage. Each light fixture runs about $65, so the cost of my entire low voltage lighting scenario ran near $1000. The fixtures aren't cheap. I use some transformers that I got at Home Depot that were reasonable and seem to do well in lighting the entire place. $30 vs $1000 is a BIG difference.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Dec 2009
    2,690
    My opinion still stands, really. Solar lights are pretty useless, IMO. A good system where the fixtures are bronze and will last for 25+ years, probably longer, will run around $200 per light, installed.
    Dec 2010
    560
    I'll add to bk406 response, where I really like my low voltage lights much better than the solar lights, but the solar lights do add to our visuals throughout the pool area. I think I spent probably on average about $80-90 per light for myself including all the electrical conduit, wire and fixtures. My fixtures are all copper and blend really well with my red wall. When spring time comes around I'll have to post some evening shots. I'm not quite done. I purchased 2 more lights this week and I have 2 more to go to be completely done. It's been a 1 year project due to cost to get my lighting in. From the picture posted, my lights are located under the first wall. You can barely make out the two lights located on the left side of the photo - one approximately 5' from the stairs and the other to the left about 10 feet. They will eventually surround the entire pool.
    TFT-100 test kit
    Dec 2009
    2,690
    I wish I had put some of those walll ights into my Vers-loc wall when they were being built. Too late now. I went with wall washer fixtures which look nice and have a great washed wall light effect. I did mine in stages too. I'm still not quite finished. I have 55 fixtures so far scattered around in various areas over 3/4 acre.
    Dec 2011
    Murfreesboro, TN
    111
    Quote Originally Posted by XsAllOverIt
    I'm considering buying a separate transformer and going the low voltage route. BK406 mentioned CAST and I've looked into those. I'm curious the brand you went with. Is everything daisychained off the same transformer? LED/Incandescent?
    Thanks
    22 x 36 In Ground Vinyl - 23K Gal - Saltwater - Tara Liner
    1hp 2-speed Hayward Super Pump, Hayward 6060 Booster Pump
    Hayward SwimClear C3030 Filter, Hayward 400Btu NG Heater
    Hayward Aqualogic PS-4, Polaris 280 Cleaner, ColorLogic 4.0 LED
    Dec 2010
    560
    I purchased a Home Depot or Lowes transformer and continue to add lights to the transformer. It was much cheaper compared to some of the CAST systems I've got at least 13 lights hoooked up to it so far, but I've got 2 lines coming in, so if needed, I'll purchase another transformer. I was going to purchase a nice CAST system, but after using this one, NOPE. Also, everything I've got is inside a pool house so I don't worry about weather with respect to the transformer. You simply need to determine the total wattage of lights and not exceed the transformer output. I would recommend buying a cheap transformer if you can keep it weather proof and see where it goes. I was running 6 lights off of a pond transformer initially and was amazed.
    These are the lights that I use: http://www.globalindustrial.com/searchR ... &x=37&y=18
    TFT-100 test kit
    Jul 2011
    Broken Arrow, OK (Tulsa)
    283
    I wonder if anyone here is using Pentair's Intellibrite landscape lights? They're interesting to me in that they can synch with the Intellibrite pool lights, and can be controlled by an Easytouch or Intellitouch system. They're easily double the price per light of what I've seen posted in here thus far.
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
    I have the Costco lights and it should tell you something that I am here looking for info on hardwired lights. The batteries stop holding a full charge after 2 months (and cost more than the lights), the lenses covering the solar cell haze over in extended sun exposure (really), and they have plastic spikes that can be broken by a child (trick or treat!)
    35k inground Plaster w/ attached spa, 2hp Pentair single speed pump, EasyTouch with Intellichlor, 48 Sqft DE filter, BBB managed
    Need a heater!
  20. Back To Top    #20
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by scurley
    I just bought some of these. They cast an interesting pattern of light due to the design of the glass shade. They cast enough light to define the edge of my pathway somewhat dimly. I like them so far.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
