Thread: Filter pressure dropping
    Jul 2010
    Albany, NY
    25
    I cleaned my cartridges about a month ago, right after we moved into the house. The pressure once I reinstalled everything was about 17-psi which was higher than I expected it to be after cleaning them. Over the past 4 weeks the pressure on the gauge has been slowly dropping. Last night it was hovering right around 15-psi. I'm not sure if I should pull everything apart and see if the filters are still clean or if they are dirty. Water is still very clean and flow at the returns is good. I haven't noticed a decrease in flow coming from the returns since cleaning the filters or anything like that. Any thoughts?
    22,200-gallon IG, Vinyl Liner, Hayward 1 h.p. Super Pump, Hayward SwimClear Cartridge Filter, Full sun 6am~7pm,. TF-100 Test Kit
    22,553
    Re: Filter pressure dropping
    If it dropped way down I'd break it apart and inspect it, but a couple of pounds isn't a big deal. The gauge could change that much without the pressure actually changing.
    Jul 2010
    Albany, NY
    25
    I'll keep an eye on it. I don't like to obcess about things, but not having a ton of pool experience (little over a month now) I questions things. Thanks.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Falling pressure usually indicates a water supply issue on the inlet side of the pump or a damaged filter element. A dirty filter would cause a pressure rise.
