Thread: How often is normal to add salt
    I have had swg sytem for about 3 weeks now. I love it to say the least. I had not checked my salt in about a week. It had been staying around 2900, but tonight it was 2500. Why I dont know. I havent lost any water. have gained some cause of rain. I added approximately 16lbs of salt to get it to where it needs to be. Which brings me to my next question. How and the heck does everyone weigh there salt? i had a half a 40lb back so I put a little less than half a bag in it.
    Intex Easy set 18x48 pool
    Intex Sand Filter
    Intex SWG system
    TF100 test kit
    Mar 2009
    Macon Ga
    77
    Re: How often is normal to add salt
    The only time you should have to add salt is from splash out or backwash where you have to add water or from rain when you have to drain some water to waste. Salt does not evaporate so as the pool water goes down the salt level will become a little higher.
    18X38 Grecian 26000 gallon In Ground Vinyl. Goldline AuqaRite SWG with a 1.5 HP Pentair Pump. Triton 2 Sand Filter Two main drains with 4 main returns with 2 more returns on the swimout and two skimmers. Polaris 380
    A couple of hundred ppm variation in the salt reading is not uncommon, but if it keeps going down something is wrong.
    I would add a little more salt. Measurements are always approximate. If you have doubts, add less than you think you need, give it 24 hours to mix in, and see what the salt meter says at that point.
