Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Plumbing + Renovation
    Oct 2007
    Sydney Australia
    58
    Hi
    I am re plumbing our pool,DIY(me), the existing pipes are old and crappy.
    I have two existing returns, approx 30mill black rubber hoses that run under the pool. I want to connect a poolskim. It's a rectangular pool with 180mill concrete walls.
    Plan to core drill concrete wall, 180mill thick, and replace existing returns with one 40mill pipe. Is core drilling easy? What size hole? Where should I locate the new return? How far under the surface? What plaster mix should I use?
    Thanks Guys
    Pools come 2nd to Sydney's golden beaches?
    21000g IG concrete pool (painted over marblesheen)
    1.5hp Waterco pump
    24"Waterco sand filter(artificial sand)
    SWCG
    Location Sydney Australia
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Plumbing
    I son't want ignore you - but give ma a day or 2 to think about this
    Luv& Luk
    -Ted
    Oct 2007
    Sydney Australia
    58
    Re: Plumbing + Renovation
    Cool. I have added photos. I have replaced the two skimmer boxes with one which is in the top left hand corner of the first photo.
    1.5hp Waterco pump
    SWCG
    Oct 2007
    Sydney Australia
    58
    Hi again
    Yep I'm core drilling tomorrow. Anybody want to make any suggestions where I should put my returns?
    Thought I might go for two returns and drill a third hole as a future provision for a pressure pool cleaner.
    Anybody have any other ideas?
    Anybody???????
    1.5hp Waterco pump
    SWCG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    How much underground access do you have? Can you get around the entire pool?
    Oct 2007
    Sydney Australia
    58
    Quote Originally Posted by Melt In The Sun
    Hi Melt
    I don't have access to the top end of the pool, that's where the existing returns are. But the remaining 75% of the pool is fine.
    1.5hp Waterco pump
    SWCG
    Oct 2009
    3,899
    OK; got it. I think you should do at least two returns; I would probably do four plus a cleaner line (you could later plumb it for either suction or pressure), if the cost and trouble isn't too bad. Having only one return is just asking for trouble. As for the locations, I don't really know...hopefully someone else will help.
    What is your plan for the finish?
    Oct 2007
    Sydney Australia
    58
    I'm looking at paint for the pool finish. Anything will be an improvement and I don't mind painting.
    1.5hp Waterco pump
    SWCG
    Mar 2007
    4,160
    Sorry for the delay in responding
    As MITS said, you want at least 2 returns (located to provide a circular flow to the pool - NOT fighting each other )
    I would put one offset on a deep end corner (~ 2.5' off the side wall) down ~ 2' from the tile. The directional eyeball will be pointed so that the water doesn't ripple until 2'+ after the skimmer box, we don't want to steal floating goodies from the skimmer .
    The other would be in the shallow end (on the long wall) ~ as close to the shallow wall as possible and point so that the water doesn't ripple for ~3' out from the wall.
    This should give you a circular flow to the pool while not trapping too much stuff against the shallow wall. If one of the skimmers habitually has much more debris trapped in it than the other, I'd put the returns on the opposite side.
    HTH
    Have fun with the core drill - I KNOW how much fun they are
    Luv& Luk
    -Ted
    Oct 2007
    Sydney Australia
    58
    Thanks waste
    I certainly did have fun with the core drill, carefully balanced between my legs, a bit close for comfort.
    In the deep end I'm 4ft off the side wall and 3ft down from the tile. The skimmer on the right hand side is history. I only have one skimmer now.
    In the shallow end I got as close as I could to the end, anyway the photos tell the story.
    I'm going to have some lunch now as I'm stuffed. Check out the brass fitting I core drilled through and the old plumbing.
    1.5hp Waterco pump
    SWCG
    Oct 2007
    Sydney Australia
    58
    Hiring a water blaster on the weekend 4000 psi. That will be fun.
    1.5hp Waterco pump
    SWCG
    Jan 2008
    Northeast Florida
    161
    I did something a little different....I installed an extra return fitting and plumbed it with a three way valve enabling me to swith it to either suction OR pressure. This way, I can use it as either a dedicated vacuum port, a dedicated pressure cleaner port, a fountain, OR just another return for extra flow.
    33' above ground pool, 52" deep, about 27500 g
    sand filter w/zeobrite
    Oct 2007
    Sydney Australia
    58
    Hey Miranda that's a great idea.
    A fountain thats interesting. How does that connect to your return?
    1.5hp Waterco pump
    SWCG
    Jan 2008
    Northeast Florida
    161
    Redneck Model T fountain, made out of scrap PVC. Goes like this: male threaded fitting screws into the return>elbow>1' of pvc>tee>two 1' pieces of PVC>2 caps. Drill 1/8" holes as needed/desired for a truly customized effect
    Oct 2007
    Sydney Australia
    58
    Brilliant! Do you have a photo to share?
    1.5hp Waterco pump
    SWCG
    Oct 2007
    Sydney Australia
    58
    Uncovered a few problems today.
    Hairline cracks running down the sides of the pool, 8 in total, some carry on through the waterline tiles and through the coping.
    Hairline crack through the middle of the floor, doesn't extend to the sides.
    Plaster looks like it has turned to chalk in a number of places just under the waterline tiles.
    Probably normal for a pool of this age, overall the plaster is in good condition but should I attempt to fix these problems or will I just make it worse?
    1.5hp Waterco pump
    SWCG
    Oct 2007
    Sydney Australia
    58
    Quote Originally Posted by Little Aussie Battler
    Morning Guys
    It's a full moon outside and I have been outside inspecting the water blasting job I did yesterday, man I got sodded
    Looks like the chalk, I mentioned in the above quote, has been blasted away, so I might be able to polish out any pit marks left behind.
    As for the hairline cracks. I can see that some have been repaired before and have not got any worse. I might explore further and open one up with the grinder. I will post a pic later.
    More water blasting today but I'll give it another hour to please the neighbours.
    1.5hp Waterco pump
    SWCG
    Oct 2007
    Sydney Australia
    58
    Here are the pics I promised.
    I highlighted the crack under the plaster with pencil. The photo shows the crack running up through the tile and the repair job below. I think the repair is standing up OK.
    The other photos show the cracks un highlighted. The photo without the tile in the picture is the crack on the floor.
    Should I repair these cracks?
    1.5hp Waterco pump
    SWCG
    Oct 2007
    Sydney Australia
    58
    1.5hp Waterco pump
    SWCG
  20. Back To Top    #20
    Oct 2007
    Sydney Australia
    58
    After a second soaking I gave up trying to remove any more paint with the water blaster. My tactics have now turned to angle grinding. I tried attaching wire cup wheels, masonry discs and a diamond disc wheel that had 2 rings of teeth. At 12500 rpm there is not a lot of margin for error. After some shocking attempts (electrical and visual) I am now waiting on delivery of a variable speed stone polisher that has a water feed. This tool looks ideal, well that's what it said on ebay. Should keep me busy for a few days.
    1.5hp Waterco pump
    SWCG
