Results 1 to 8 of 8
Thread: New AGP owner
    Jul 2010
    Central Illinois
    50
    New AGP owner
    Hi all...let me be more exact. I have been one of the guys that have fought with an Intex pool for the last 10 years or so ( 3 different pools). Let me tell you I will not miss tearing down and putting up the pool every year...or fighting with the lack of proper filtration.
    Let me explain that I do own a hot tub as well so I understand the chemistry portion somewhat of pools and spas.
    I go this coming friday to pick up my new 18 foot 52" pool. With this pool I am getting a 2hp hayward 110 cartridge filter and pump, the Zodiac Pro A-vessel which holds the Pro Vision Purifier and chlorine tabs.
    While I do have somewhat experience with pools I would like to treat myself as someone that has no clue...rather than someone that has learned things that are wrong. So having said that...I will be very thankful for anyone willing to help me out as if I had never had a pool before.
    As an outsider looking in...I would think that my filtration system might be overkill for the size of pool that I am getting. But I have been assured that the filter is designed for the size of motor that I am purchasing. It is actually a friend of mine who owns one of The Great Escape stores that sold it to me. I know he would not stear me wrong...or at least I hope not. I will not know for the next couple days of an installation date. I am currently draining my 18 foot Intex so that the ground will be somewhat dry and workable for the install team when they arrive.
    I plan on filling with the small initial amount of water with my hose...however I will have the fire department come down and do the mass of the filling (is there anything that I need to be careful with in regards to this?)
    Once again...I will truly appreciate any and all advice aka help that I can get!
    Thanks much,
    Doc
    1) 8500 Gallons (18 foot, 52 inches deep)
    2) Hayward Cartridge Filter
    3) Above Ground Pool
    4) Hayward 2 HP pump
    22,544
    Re: New AGP owner
    Welcome to TFP.
    Having the FD fill your pool if their trucks have aluminum or stainless steel tanks is a great idea.
    There have been a few people that have had their pools filled by the FD and wound up with rust in their pool. Just something to ask before. Even if they have steel tanks if the water has been drained and replaced it should be fine.
    Jul 2010
    Central Illinois
    50
    Re: New AGP owner
    Thanks Mod for the heads up! If there is small amounts of rust....I take it that the filter will take care of it...correct? Please...any and all advice will be greatly appreciated!!!!
    22,544
    Re: New AGP owner
    If the flakes are big enough the filter will filter them out.
    I always recommend getting an assay (water report) on the water you're putting in your pool. The utility the water is coming from can tell you where to get one.
    Jul 2010
    Central Illinois
    50
    Re: New AGP owner
    Well...I am on the village board (town of 1000 people) I can tell you that our ph runs high. I know that ph is a strong contributor to how chlorine works. Is muriatic acid safe to use with pool liners?
    22,544
    Re: New AGP owner
    Muriatic acid is not only safe but the preferred chem to adjust pH downward in every type pool. Do you have the rest of the numbers
    pH
    FC
    CC
    TA
    CH
    Iron
    Copper
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Re: New AGP owner
    Most of the newer fire trucks have POLY tanks and usually the rust comes from not flushing the hydrants properly .. Just ask before they start and also if they used any foam in their tank lately--if they have you may want them to do a few flushes first.. Being a fireman here --just no telling what the water came from ..
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    Jul 2010
    Central Illinois
    50
    Re: New AGP owner
    Thanks much....no numbers yet on the water. I can say with confidence no foam. We are a small community. I will take a sample to pool place friday when i get the pool to post numbers,
