Results 1 to 9 of 9
Thread: Need light recommendation for above ground pool
    Jun 2010
    San Antonio
    424
    I am looking for recommendations for a light to my above ground pool. I would like it bright enough to be able to see the pool bottom and at the same time be aesthetically pleasing. What do you recommend?
    Thanks, Larry
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Re: Need light recommendation for above ground pool
    My vote is for the Smartpool Nightlighter NLMC... It is a mulitcolored that can stay solid on one color or fade to into the other colors. I did change out one bulb to a solid white one. here is a link to it for only 99.99 http://www.poolsupplies.com/cgi-bin/com ... add=action
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    22,539
    I have a Nightlighter NLMC Multicolor and it illuminates the pool well. BUT (isn't there always a but) it failed a few days ago. It's still under warranty and I've sent it back so I'll report back on how that goes. Hopefully it's just one bad unit and not a design flaw. I do love the light. The colors are great and the light is plenty to light up the pool.
    Jan 2008
    Northeast Florida
    161
    Be aware that this type of hanging light will not hang on some pool designs. You need to remove the top rail, hang the light from the pool wall then reattach the top rail. My pool has plastic top rails that fit tightly over the liner channel, there is no way to hang the light and get the top rail back on.
    33' above ground pool, 52" deep, about 27500 g
    sand filter w/zeobrite
    Jun 2010
    San Antonio
    424
    Thanks for the suggestion. I also have plastic top rails. I will have to look to see if I have any clearance over the liner channel. Any idea how much clearance I need? Have others had problems with this light failing?
    Larry in Texas
    22,539
    I haven't heard of any other failures.
    You'll need a space about 1/2" high and about 2" wide. My pool has resin top rails and it fits perfectly.
    Jun 2010
    San Antonio
    424
    My top rail sits right on top of the liner, that is looking at it from inside the pool there is no gap. But, the rail seems to have some give when I push up on it in the middle. It might have enough flex to allow for the mount to fit under it.
    Larry in Texas
    22,539
    I also thought mine sat right on top of the bead carrier but after I removed it I found that there's a criss-cross pattern and there is enough space for the NLMC to fit without bowing the top rail up.
    Jun 2010
    San Antonio
    424
    Maybe it will work for me as well. I have several broken top caps and need to take one off to see if I can find a replacement. I will check the top rail at that time.
    Larry in Texas
