Thread: Question About A Diverter Valve
    I have a big oval Doughboy above ground pool. The deck is built around it, and most of the plumbing is under the deck. My pool has two returns, one on the bottom on the deep end, and one on the side. Pretty standard.
    There is a Hayward Dial-A-F....(something, the sticker is torn there) valve where I can choose to from 4 different settings: A - (sucks in water from the top return only,} B: (bottom only) A+B (both) and "Off"
    It has a leak. Looking at this illustration, http://www.poolcenter.com/parts_valves_hay_sp732.htm (which I found via Google images. I know nothing about that site) the crack is in #4, the cover.
    But I can't find a model number on my valve. Would this be a 3-way, even though there are actually 4 positions?
    ~17,500 gal outdoor 18'x34' oval Doughboy pool; Haywood 1 HP Super pump; Haywood Pro-Series Sand filter
    Re: Question About A Diverter Valve
    Yes, that is a 3 way valve because it has three pipes going into it.
    South Central NJ
    3,192
    The middle port is common. Call this #3 port
    Assume #1 is the left port
    Assume #2 is the right.
    The 4 positions are really 3: 1 only, 1 & 2, 2 only, 2 &1
    1 & 2 and 2 & 1 are the same thing.
    Most techs HATE these valves. I replace them when I can with Jandy Never-Lubes or similar 3-Way valves.
    Scott
    Owner of - PoolGuyNJ LLC
    Thanks so much. Good to know that I might be better off replacing it next time, too.
    If I do that, I'll also move it to a place where I don't have to crawl under the deck to reach the dratted thing.
    I was hoping to avoid buying a whole new valve. The replacement cover is only $20 shipped, so I'm starting there.
    Now I have to figure out how to take it apart without accidently draining the pool.
