Thread: what to do about bees in the pool?
    Mar 2010
    Huntington, WV
    150
    This is our first year open with our new AGP. I notice there are alot of these shiny, gold colored bees and they are usually on the surface of the water. They sting which makes the pool very unattractive for swimmers. I vacuumed the pool just now and went around with the leaf rake and would get about 5-10 bees each time around.
    What is a good solution for these pests?
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    Apr 2010
    West Hollywood, CA
    32
    Re: what to do about bees in the pool?
    I just skim them off and enter the pool and watch for new ones hovering trying to get a "sip" of water and shoo them off. The ones that land in the water get fished out. They do prefer the water during the sunniest part of the day. I also observed they are especially drawn to red/orange/yellow floats so I avoid buying inflatables in those colors. That has helped while you're in the pool. There might be a hive nearby and they are looking at the closest water source? I have a lemon tree near the pool that attracts bees but they don't all necessarily drop into the pool. Other than that I can't explain why you're inundated by so many. I'd say I get a total of 10 in a 24 hour period. I just consider it the "cost" of having a large body of water available to critters, winged and otherwise!
    [center:3jp7r7gm]15'x25'x4' Oval Muskin AGP, blue vinyl liner, sunk 2 feet in ground with redwood decking. Approx 10k gallons. Hayward Perflex filter D.E. and Hayward 1.5 hp pump. One return line. Wedding cake stairs. (whew, hopefully that describes the pool!)[/center:3jp7r7gm]
    chessie6's Avatar
    East Hartford, Connecticut
    187
    Just to make sure, are you referring to the little bees that are also neon green in color or striped? These are called sweat bees and are actually a valuable pollinator of our food supply. Being pro-animal, insect and all, my suggestion would be on the side of diverting them away from your pool rather than killing them, but I can certainly understand their annoyance to you because we have quite a few of them here as well and those stings really grab your attention. I keep my returns focused upwards in order to break the surface of the water up rather than having a shiny mirrored surface, and also have another body of water available for them to get their water from (it's a small garden fountain, but a birdbath is good too). I read that having a hummingbird feeder nearby will draw them because of the sugar in the food. And, of course, skimming them off. I keep a net by the side of the pool to use even when I'm swimming.
    Good luck and enjoy your new pool!
    Summer: 19 x 37 Pacific Graphex IG modified oval, aztec marine vinyl liner, 24,000 gal, 3.5 feet to 8 feet, 1 hp Hayward C4025 Swim Clear 4-cartridge filter, 12.5% Liquid Pool Shock for sanitizing, 1 super wide mouth skimmer, 4 returns (2 therapy jets in steps), Hayward Heat Pro heat pump, non-curved pool slide, 6' jump board, 8 ml blue solar cover, TF-100 test kit, had pink algae in 2010 Winter: Hot Springs Vista Spa, 500 gallons.
    Mar 2010
    Huntington, WV
    150
    Yea, I am pretty sure they are sweat bees, now that you have mentioned it. I dont care to divert them, just as long ad they don't disturb me, my pool and my little swimmers.
    24' AGP
