Thread: CYA and pH
    Dec 2009
    San Antonio, Texas
    78
    CYA and pH
    Does CYA affect pH? Specifically, does a low CYA affect the pH test and therefore require adding muriatic acid in order to balance pH?
    I'm having trouble balancing my pH and have low CYA. Before I post specifics I'd like to know about the CYA/pH interaction, if significant, and perhaps try raising it.
    Thanks.
    Jaywalker
    In-ground, 11,000 gallon, plaster, in-line trichlor pucks or BBB bottled chlorine, 1.5 HP pump @ ~100 gallons/minute, cartridge filter
    30,432
    Re: CYA and pH
    Short answer...no relationship.
    You can have pH low at 6.6 and your CYA can be zero or 120...they are not related.
    Dec 2009
    San Antonio, Texas
    78
    Re: CYA and pH
    Thanks. Then I have a problem I'll post separately.
    Jaywalker
