Thread: NEW WRINKLES IN VINYL LINER ALONG WALL QUESTION
    Jun 2010
    Tennessee
    138
    Hi All....We had a really heavy downpour a few days ago and my pool filled past the top of the skimmer inlet. I drained some of the water out but not to the middle of the skimmer. Was planning on using the extra water to vacuum to waste. My two sons and nephew got in the pool and my oldest started jumping up and down causing the water to rock overflowing water out of both sides of the pool. The next day I got in to vacuum and noticed that there are now wrinkles along about 8 ft. of the wall on the skimmer side. Wondering if water got between the wall and the liner or if the wrinkles came from when I drained half of the water a while back due to my high CYA level. Or maybe the liner is just getting old.? We have had the pool for 10 years now and have never replaced the liner. It is a beaded liner and I also noticed that there is a spot that looks like it is coming loose from the top. Any opinions?
    30' Round Vinyl AG, 21,200 K GAL. with Main drain, Hayward 1.5 HP Pump, Sand filter, BBB Method & TF~100 Test Kit
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: NEW WRINKLES IN VINYL LINER ALONG WALL QUESTION
    how acidic is the water?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jun 2010
    Tennessee
    138
    PH is 7.5 stable and TA is 130 And CYA is at 80
    X-PertPool's Avatar
    Exeter, PA
    1,385
    take a couple pictures of your pool, it could be a high water table but it's unlikely since your pool is above ground.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
