Thread: Pentair Dynamo Discrepancy
    I'm looking to get a Pentair Dynamo 2 speed, and I saw this picture and I notice there is a male npt for the output.
    Then I ran across this drawing of the dynamo pump and I notice there's a female npt for the output.
    Can someone who owns one actually confirm which it is?
    If it is a male, can someone point me to the proper adapter to hook a hose up to it? I can't seem to find one. Or maybe I'm looking right at it, and still can't see it.
    Thanks!
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    Nov 2009
    Indialantic, FL
    323
    Re: Pentair Dynamo Discrepancy
    Don't own one, but saw one in a local strore - had the male threads on the outlet like your photo, but it also had a threaded collar that fit those threads. Looked like it was designed to tighten some sort of a flanged output line (or maybe an O-ring?).
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Hmmmm... Maybe that's not a NPT then.
    Rob B
    It is threaded on both the inside and the outside. The inside is standard NPT 1.5". The outside is something else, designed to go with a special Pentair union connector.
    Thanks Jason! That'll work.
    Rob B
