Results 1 to 8 of 8
Thread: Complete Drain and Refill
    Jul 2010
    Ft Worth, TX
    3
    I completely drained my pool and it is almost refilled. I want to come onboard with the BBB... Where do I start.
    According to Leslies:
    FC = .5
    PH = 8.0
    TA = 150
    CH = 160
    CYA = 0
    Phosphates = 300 (wants to sell 64 oz of PhosFree)
    15K IG Pebble Tec - Pentair DE filter - Polaris 280
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Complete Drain and Refill
    First and foremost Test Kit!!!
    Do not buy PhosFree.
    Are you familiar with the pool calculator? (link in my signature)
    Add:
    • Bleach or Liquid Chlorine to get up to 2
      CYA (stabilizer) to bring CYA up to 30-50 (depending on how much sun exposure). Hang in a sock in front of a return with the pump running.
      Muriatic Acid to bring pH down to 7.5
    You can do these pretty much at the same time (let the bleach mix for a while before adding acid).
    You can massage the sock periodically to help the CYA along.
    Once the CYA is dissolved, assume that you have reached the target and dose chlorine based on that. (chart link in my signature)
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jul 2010
    Ft Worth, TX
    3
    Thanks for the quick response.
    I was duped into buying PhosFree a couple of months ago, before discovering TFP, and learning it was a scam.
    I am on my way to a different Leslies to buy CYA, Muriatic acid, and a test kit. I am taking a second sample to this store to see what they show, then I will test it with my new test kit, myself.
    I have already bought Borax, baking soda, and chlorine. When does the Borax get added?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I highly recommend getting an FAS/DPD test kit. I am 99% sure that you will not find one at a pool store. Taylor makes the k-2006 wich is fine, but not as good a deal as the TFTestkits TF-100 that I linked to above. The k-2005 is NOT the same.
    Borax has two purposes:
    1. To raise pH. You may never need to do this as your pH will likely drift up over time.[/*:m:1zxyeia2]
    2. In large quantities (along with large quantities of muriatic acid) to bring borates to 50ppm. This is and advanced BBB technique to stabilize pH and also acts as an algicide.[/*:m:1zxyeia2]
    Baking soda is to raise TA. You don't need this either (TA is already high).
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    While you are at the pool store, pick up some hardness increaser (calcium chloride). Your CH is about 100ppm low.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Given your current numbers you don't need the borax, keep it though you may need it later. (Borax rasies pH yours is already too high, depending on local conditions (type or soil that gets into the pool, type of fill water, pool finish, etc.) it may drift up or down)
    Ike
    p.s. if you have already bought a K-2005 kit it can be useful in managing your pool if your CYA levels are under 40 ppm, you could upgrade it with just a FAS-DPD chlorine test and have about the same thing as the K-2006 or TF-100 (I also think the TF-100 is the far better deal)
    Jul 2010
    Ft Worth, TX
    3
    Thanks for the replies. I picked up the hardner and CYA, and left without a test kit. Figured I have time to get the right kit.
    This Leslies shows:
    FC = 1.5
    PH = 8.0
    TA = 100
    CH = 150
    CYA = 0
    Phosphates = 0
    Wonder how I got my phosphates to lower that quickly
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by TFPFan
    Inaccurate testing. Now you know, and knowing is half the battle
