Thread: question about CCs
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    question about CCs
    I know in order to bring down CCs you are supposed to shock. But does raising the FC a bit but not to shocking numbers also have the ability to bring down CCs?
    4 days or so ago my numbers were:
    3 FC
    35 CYA
    .5 CC
    7.6 PH
    70 TA
    So I brought the FC up to 8 and a few days later my numbers are:
    5 FC
    35 CYA
    0 CC
    7.6 PH
    70 TA
    My question is, what is the likely reason my CCs went down? Is it just because whatever organics the CL was breaking down was finished or is it possible that raising the FC to 8 and keeping it a drop high for about 2 days brought the CCs back to 0?
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    30,415
    Re: question about CCs
    Any elevation in FC will contribute to diminish CC's. Sunlight on your pool also helps.
    Don't worry about your results too much. For our purposes here on the forum, .5CC is the same as ZERO.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Excellent! Thanks
