Thread: UV System - Does it work?
    New pool going in next week. Was going to go salt water chlorinator, but recently swam x 2 in a pool with one and developed an insanely itchy nose! Maybe I'm allergic to something that system is putting out, so I'm considering regular old chlorine plus ultra-violet. Pool is small - 10 x 20, only 5 ' deep, it will be kept covered about 2/3 of the time. The weather here is very hot but no kids, no mess. My pool man is suggesting Baquicil but everyone in your forum seems to be converting out of it.
    What to do?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    Re: UV System - Does it work?
    We installed a UV system in our pool when it was built last year. I didn't want the possible corrosion issues with salt water. Having said that, I think if you want an easy to maintain pool with minimal "intervention", salt might be your way to go. In hindsight I wouldn't recommend a UV system since your going to need to add chlorine somehow as the UV just disinfects the water going through it, and does nothing to disinfect the pool water that's actually in the pool, hence the need for chlorine in the pool water.
    What I found works great for me is using something called the Liquidator. There is a forum here that should answer any questions you have on that. It's not as install and forget as a salt water, but it's one of the best things I've bought for my pool and it works great.
    It's like everything in life....compromise....you'll maybe never find the perfect system, but you should be able to find one that workds great for you.
    Good luck...
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    SWG pools can be some of the least allergy/irritation triggering pools of all if they are managed well. Operated improperly they can have all the usual problems that any pool can have. Almost no one has a true chlorine allergy, nearly everyone reacts to CC, which only develops when the pool is managed poorly.
    UV doesn't do much for an outdoor residential pool, you have to use chlorine anyway and chlorine does so well that there isn't much for the UV to improve on.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    There could have been something going on chemistry wise and the pool was out of balance... which was causing you to react.
    Quote Originally Posted by flyboy320
    But do you like your UV system? I'm attracted to the idea of it. Or what about ozones?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    The TFP method recommends chlorine sanitizer maintained at the appropriate level for a given CYA level.
    If you re-read flyboy320's post he said he wouldn't recommend it.
    Check out this post where waterbear (one of the most respected members here) debunks all of the common alternative sanitizers.
    You are not going to find many people here with positive things to say about alternative sanitizers. At best they are expensive and unnecessary, and at worst they are dangerous (in that you really don't have sufficient sanitization ).
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
