Thread: New Pool-what should I do??
    Near Nashville TN
    50
    I will be filling up my new 20x40 IG vinyl in a few days. i have an Autopilot SWG- what should I do on day one to start my chemicals-
    I think I should add:
    CYA to a level of around 60-70??
    Bleach to start before salt kicks in- not sure how much
    baking soda for PH?? Or borax??
    Thanks for help
    20x40 In ground Grecian Lazy L- Vinyl
    AutoPilot SWG Dig-220, SC-48
    Hayward Dual speed 1.5 hp pump
    Hayward sand filter
    Blue Diamond Robotic Vacuum
    BBB method BABY!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: New Pool-what should I do??
    Get a test kit quick, before you start adding water. If you know what the fill water contains, you'll have a pretty good idea of what you'll be needing before the first drop of water hits the vinyl.
    Bookmark Pool Calculator. That and your test kit will be your best friends for a few days at least.
    http://www.troublefreepool.com/pool-...ary_pool_guide has easy instructions that will tell you what to add when. Ignore the "temporary" part - it's the same process for you.
    Once you get a test kit, or if you can get a pool store to test your water for you, you should post a full set of water test results. Then we can give you specific recommendations of what to do.
