Results 1 to 8 of 8
Thread: Cover sinks into pool every year
    I've had my house for 9 years and every single year, after the pool thaws in the spring, the pool cover sinks into the pool. I can never find a hole anywhere and replacing the cover every year is getting old...
    24' round Vinyl lined Sharkline pool, 4' deep
    13,500 gallons, buried 1 foot deep
    1.0 hp pump
    Hayward EC-65 DE Filter
    Polaris 65 Automatic Pool Cleaner
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Cover sinks into pool every year
    Do you pump any water off the cover?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Why not buy a mess of PVC pipe and some fittings and build a little pyramid that sits in the pool and makes the cover drain? I've never lived anywhere that freezes up in the winter, so there may be some reason not to; if so, I'm sure someone will point out the drawbacks.
    Dec 2009
    Central Massachusetts
    2,690
    Have you ever used an air pillow? They are supposed to work.
    Not sure about the PVC idea. I'm not sure I would want something like that sitting on a vinyl liner all winter. It might be ok, might not.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    there is an ag cover out there that has a drain in the middle that the water funnels to and then it drains out a pipe that connects to the return line.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Quote Originally Posted by X-PertPool
    I pump water off the cover, but since the cover is below the water level, I end up pumping out half the pool to get the cover out.
    Andy
    1.0 hp pump
    Quote Originally Posted by bk406
    Two years ago I bought 2 air pillows. After the pool thawed, the cover sank and I found out both air pillows had popped.
    1.0 hp pump
    My local pool store claimed that I need to pump the water off the cover after every rain storm. I asked him if that was the case, what the **** was I supposed to do with all the snow on the cover? He didn't know what to say.
    1.0 hp pump
