Thread: Fiberstars Jazz Light
    Lallers's Avatar
    Jun 2010
    Thousand Oaks, CA
    3
    I have a set of Fiberstars Jazz Light J-400.
    After I replaced the water in my pool I can't get a single light to turn on.
    I have 4 on the pool and on a separate circuit I have one more in the spa.
    I've checked the breaker and GFCI and it's ok.
    The relay turns on as it should.
    I've followed the wires as far as I can and I got power there.
    I have used a contactless voltage tester at the light and I got power there.
    I even tried with a new lamp and no luck.
    What am I missing?
    Help me so I can and
    Anders
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Fiberstars Jazz Light
    Hmm. No idea.
    Lallers's Avatar
    Jun 2010
    Thousand Oaks, CA
    3
    Well after some "help" from fiberstars there was only one solution.
    Replace the whole fixture. Not so cheap.
    Jul 2010
    North Central KY
    20
    Ouch! Sounds like they wanted to help you send them $$$..
    22,550
    What exactly did they/you determine the problem was?
    Lallers's Avatar
    Jun 2010
    Thousand Oaks, CA
    3
    They determined the unit was broken, duh.
    Just like squidlarry said. They helped me to send them some $$$
    I could see the lamp starting to arc, and the nothing else.
    Got a new unit from poolsupplyworld.com and it started up bright as a day right away.
