Results 1 to 8 of 8
Thread: Question about posting links
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I'm not sure I know how to ask this but here goes. When you post a link, how do you make the link appear as here
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Re: Question about posting links
    You use the url command. When you enter it, it should look like:Which shows up in the post as: http://www.troublefreepool.com/index.html
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hi Lynn
    I use the here.
    You can simply copy and paste the address to make it show up as Jason posted, without using the [url] option
    Luv& Luk
    -Ted
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Hey Ted
    question-about-posting-links-t24988.html
    I know how to copy and paste, like I did above. But how do you make all the jibberish above appear as just the word here. I've seen posts where all you clicked on was the word here and it took you to the link.
    Lynn
    Butterfly's Avatar
    South Carolina
    10,045
    You mean like this?
    here
    Select url and then:
    add your title here
    For your purposes, the 'add your title here' part will be the word 'here'.
    You're done SLAMing when:
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    here
    I think I've got it Only took me about 30 attempts
    Thanks sooooo much
    Lynn
    Mar 2007
    4,160
    Lynn, congrats both on figuring out the linking and
    on YOUR 500th POST
    We all value you as a member here
    Luv& Luk
    -Ted
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Wow Ted. I had no idea I had that many posts That's what happens when one has soooooo many questions to ask Maybe one day I can start answering more than asking. You guys are the greatest
    Lynn
