Results 1 to 8 of 8
Thread: New to SWG, what to do about .5 CC
    I just tested my water. FC is around 5.5 and CC .5. All other level in perfect range. Since I am new to using a SWG, what do you do when you get .5 or higher CC? Superchlorinate? Run higher % output for a few hours??
    Feb 2008
    Denton, TX
    5,061
    Re: New to SWG, what to do about .5 CC
    Unless it is greater than 0.5 ppm on the CC, you don't need to shock. Anything from 0.5 inclusive, all the way to 0 is fine as long as you are at your target FC for your particular CYA level.
    What do you do when CC are more than .5 or 1 and you have a SWG?
    Mar 2009
    Huntsville, AL
    156
    Shock by adding chlorine (bleach,...) per the Pool School article under the "How To" section. Here is the direct link:
    http://www.troublefreepool.com/pool-...king_your_pool
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    What is the "superchlorinate" function of the SWG used for?
    Apr 2009
    Northern Virgina
    55
    You can use your SWG to shock using the superchlorinate function instead of adding bleach, but it will reduce the life of your cell.
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by JimM01
    ..and probably isn't quite as effective since you don't get that instantaneous increase of FC that you get from dumping chlorine straight in.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Oct 2007
    Valrico, FL
    542
    One way to use is if you are having a large pool party, set it on super chlorinate for several hours to keep the FC level up.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
