Thread: cartridge cleaning
    cartridge cleaning
    What are some of the tricks you pros have used for cleaning the cartridges? In the past I have just used a high pressure spray but I am looking for something more efficient or effective.
    15,600 gal, Pebble tech
    1.5 hp Northstar
    Hayward SWG
    cartridge filter 425sqft
    Hayward heater
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: cartridge cleaning
    This might be of some help.
    how-to-clean-a-cartridge-filter-t4465.html
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Feb 2008
    Denton, TX
    5,061
    Use care when spraying water on the cartridge filters. You don't want to get too aggressive or you might damage the filter membrane.
    "use care" means regular garden hose, don't use a pressure washer.
    Thanks all. I have used the garden hose for the spraying, nothing higher.
    The acid idea listed in the other post was interesting but would use lots of acid.
    1.5 hp Northstar
    Hayward SWG
    Hayward heater
