Thread: No chlorine problem and solution
    Apr 2009
    Philadelphia PA area
    30
    I thought I'd summarize a recent issue I was having with my Pool Pilot SWG (see my original post here http://www.troublefreepool.com/pool-...ne-t24030.html) and the solution in the hopes it will enlighten others.
    Problem: SWG not generating any chlorine, constantly reads OFF, and a system test shows 0V.
    Solution: SWG was configured to use a remote - I don't have a remote. Set it to use the External Timer instead. Also had the cell type misconfigured (set it to SC-48).
    Changing these settings requires going into the Installer menu - you have to hold the button down for ~13 seconds so it's hard to do accidentally. But somehow I must have because it was working earlier in the summer. Chalk one up to operator error ...
    30K IG Gunite 710 sqft - Jandy 2 HP Pump - Jandy 60 sqft DE filter
    Polaris 380 Cleaner, Pool Pilot DIG-220 SWG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: No chlorine problem and solution
    Glad you got it figured out. Thanks for the tip!
