Thread: CYA Mystery
    Jun 2008
    Avon Park, FL
    15
    CYA Mystery
    About a month ago, I had water tested at Pinch A Penny and they said my CYA was around 90 or a little higher. I took out the tablets and haven't used them since. I had an algae problem a few weeks ago and got it cleared. I also recently purchased a SWG and got my new TFTest Kit in today. When I took the sample for CYA, the black dot never disappeared which means the CYA is low. How could it have dropped so low already. I know I did the test right.
    15200 Gallon, Vinyl, Cartridge Filter 100 GPM, SWG
    22,551
    Re: CYA Mystery
    Since you know you did the test right it's really low.
    We've been having several posters with CYA mysteriously going to zero this year.
    We know that there is a bacteria that converts CYA into Ammonia but we don't fully understand the particular instances when this happens. A leak with a lot of refill will also drive the CYA down a lot. This is most common with an autofill where it adds water without the owner realizing it.
    That and Pool Store CYA tests are notoriously inaccurate.
    30,424
    Re: CYA Mystery
    That's my bet.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: CYA Mystery
    That's my bet.
    And the cl test, the pH test, the alkalinity test, and the calcium test!
    Luv& Luk
    -Ted
    Re: CYA Mystery
    Pool Store...tests are notoriously inaccurate.
    WAIT! Let's be fair here...
    Pool stores can be EXTREMELY accurate!
    Just call them and ask for a price on something.
    17k in-ground, Pebble Sheen finish (Blue Granite), Solar, two skimmers, split drain.
    IntelliPro VS-3050, IntelliChlor IC40, EasyTouch 4 control system, Easy Touch wired indoor panel.
    300 CuFt cartridge filter. Polaris 380 with booster pump. Two IntelliBrite 5G lights.
    TF100 test kit.
    Re: CYA Mystery
    LOL..good one Folsom!!!
    I actually (for kicks) brought a water sample to my local pool store the other day and - just as this post suggested - the CYA level they gave me was VERY wrong. I've been consistently getting a reading between 50-60 and they actually told me it was 30.
    20'6" X 38'6" (609 sqft)
    22,500 gal gunite/plaster IGP
    DE filter, Jandy 2HP pump, Nature2 Sanitizer (removed cartridge!)
    Raypak 39.9K BTU gas heater
    2 ColorLogic lights, Maytronics Dolphin pool cleaner
