Thread: How Do I Test for Metals?
    I use a well for my water. How do I test for metal in the water?
    ktdave's Avatar
    Katy, TX
    You can start by taking a sample to a pool supply store. They will test it for free (normally).
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Most people go to a pool store for metals tests. To test yourself you will probably need to get test kits specificaly for metals, as metals tests are not usually in the standard kits. Leslie's web site sells a reasonably priced low range (0.05 to 1.0 ppm) copper test kit. The iron test kit is a bit more expensive. It is also possible to get a test for manganese, though it is far less common to have a problem with manganese.
