Results 1 to 13 of 13
Thread: could my skimmer have eaten the skimmer sock?
    Aug 2009
    SF Bay Area (Lamorinda), CA
    122
    Maybe I'm just paranoid AND forgetful - I remember cleaning out my skimmer sock recently and thought I put it back on the skimmer basket, but maybe I didn't? Anyway, this morning I see no skimmer sock on the basket and (perhaps because I have fresh memories of a giant soap-scum-and-hair clog that hubby cleared from the kids' bathroom sink) now I have this fear of a wad of skimmer sock somewhere between the skimmer and pump basket collecting all sorts of plant detritus behind it until the pump explodes from overexertion.
    So - supposing the skimmer *did* ingest the sock - what would be some obvious signs (other than the sock making its way into the filter basket)? Is there any way to flush it out? I assume the "backflush" setting of the filter runs water to waste, not back to the pool.
    Help!
    1950's-era 17K gallon formerly fiberglass, newly replastered IG rectangle (~15x30'),
    Hayward S244S Sand Filter with Franklin Electric 0.75 HP motor and WhisperFlo WFE-3 pump
    Clear ThermaTex bubble cover
    Manual vacuum
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: could my skimmer have eaten the skimmer sock?
    Check in your pump strainer basket. If it somehow slipped around the skimmer basket, it probably be there.
    Aug 2009
    122
    I checked/emptied the pump basket this morning and no sock there. But I'm still worried that it could have gotten stuck somewhere in the pipe on the way to the basket, like a section where the pipe makes a right angle turn or something. Anything you experts know that could reassure me that my phobia is an unlikely one?
    Manual vacuum
    22,553
    If your flow out the return(s) is the same and your filter pressure is the same you most certainly forgot to put it back in the skimmer. Even if it did eat it there's a strong possibility that it would have gone straight to the pump basket.
    For peace of mind you can use a drain king to run water backward through the skimmer line to try and flush it out.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Do you put it on the inside of the basket? This came up in a post a while ago. Someone was putting their skimmer sock on the outside of the basket and was very lucky it didn't get sucked in.
    Cautionary note to readers: Skimmer socks go inside the basket.
    If you did forget to put it back on, where is it? Shouldn't it be around somewhere?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Aug 2009
    122
    Quote Originally Posted by svenpup
    Yeah, I put it inside the basket. And yes it *should* be around somewhere if it wasn't put back on, but, well, um, let's just say that our pool shed is not exactly a well-organized and tidy place
    Manual vacuum
    Do you have raccoons? I ask because from time to time, I see that the skimmer sock has been pulled though the little hole in the top of the skimmer lid. I suppose the raccoon that lives under the deck thought there was something edible in there. He also sometimes has gotten the lid off.
    Aug 2009
    122
    Quote Originally Posted by anonapersona
    Yes, we do! They've been trying to dig up grubs in our lawn. Hmm, wonder if one of them ran off with our filter sock? For once, I'm actually *hoping* that the raccoon was responsible for something disappearing!
    And it *does* seem like a more plausible scenario than the filter sock coming undone from inside the skimmer and getting sucked down. It sort of pops up when the pump is off, maybe that's when a raccoon noticed it and fished it out?
    Manual vacuum
    Yup, that floating skimmer basket with the sock on it bobs around and could look like a frog to the raccoon. I finally dropped a large rock iinto the basket to keep it down.
    Aug 2009
    122
    I found the missing sock . was brushing the pool tonight and saw something hazy getting stirred up by the brush (sigh, neglected the pool for a couple days and now I need to shock it), fished it out and sure enough it was the missing filter sock, rust stains from Ye Olde Skimmer Basket and all. Will need to replace it though - that last round of Bleach Blanket Babylon really hastened the demise of the fabric.
    Manual vacuum
    So, no way it went through the system, the filter basket and filter would have caught it. Must'a been the raccoons.
    Yes, the socks are consumption items, but so much better than opening the cart filter to clean. I found an online source that costs $3 for a 5 pack of socks http://www.poolproducts4less.com/search.aspx?find=sock
    Aug 2009
    122
    Yeah, I can just imagine the raccoon wanted to wash off the 'frog' in the pool and it floated away and sank
    Thanks - that's a great price!
    Manual vacuum
    May 2017
    Neptune, New Jersey
    2
    I, unfortunately, put mine on the outside and now I'm having an issue. Never used them before and the skimmer basket I use has a bar across it so it made sense to me, at the time, to put it on the outside. I went to go grab from the 2nd skimmer basket and before I could retrieve it, the sock got sucked back into the system. Now what?
