Thread: Test Result Numbers
    Test Result Numbers
    Hi all,
    I've been keeping up so far with the pool but have just completed about 8 days of heavy useage. 5 nephews and assorted others have probably taxed it pretty good.
    My numbers this morning are the following:
    FC=2.5
    CC=.5
    TC=3.0
    pH ~7.2
    T/A=60
    I had added ~ 1/2 gal of 5.25% bleach earlier before testing. In previous testing I didn't register any appreciable CYA.
    Any insight would be greatly appreciated.
    Our weather in the NE has been hot, hot and muggy and the heat looks to continue.
    Thanks much,,,,,,,
    Ct. Pooler
    16x32 IG ~ 23k gal
    Vinyl lined concrete sloping hopper deep end
    Hayward DE 36ft2
    Hayward BA heater not being used
    Gales Ferry Ct.
    30,432
    Re: Test Result Numbers
    Tell us how your water looks.
    What is your CYA level?
    Are you having water quality issues?
    Butterfly's Avatar
    South Carolina
    10,045
    Since you were unable to get a read on your CYA test, it is either all gone or very low. I suggest you add about 30 ppm CYA and retest in a week.
    After the CYA has dissolved, assume it is your new CYA level and maintain chlorine accordingly (min. 2 target 4 to 6)
    You're done SLAMing when:
    Dave & Butterfly,
    I did omit that I have what I think is an accurate reading of 30 CYA. The water is cloudy at present. I had been adding chlorine stabilizer but I am out and need to get some more.
    Thanks again,
    Ct. Pooler
    16x32 IG ~ 23k gal
    Hayward DE 36ft2
    Gales Ferry Ct.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Your PH and TA are on the low end of acceptable and the low PH could cause some irritation. I'd suggest some Borax to get it to the mid 7s.
    Then I'd add enough FC to reach 10, and then tonight do an Overnight Loss test to see if your FC is holding overnight. If it doesn't you should shock, considering the cloudy water.
    (this all of course assumes you will go ahead and raise the CYA level.)
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by hillerji
    ...I did omit that I have what I think is an accurate reading of 30 CYA. The water is cloudy at present. I had been adding chlorine stabilizer but I am out and need to get some more...
    Your wording here concerned me...CYA is the same thing as "chlorine stabilizer". When you say you are getting more, what is your CYA target?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
