Results 1 to 8 of 8
Thread: Vacuuming trouble
    Mooresville, NC
    32
    Vacuuming trouble
    Hey everyone,
    I did a search and I still can't find what I need. I'm also not sure if this is the correct area.
    When I vacuum my pool it doesn't seem to be getting rid of the debris or dirt. Here's what I do when vacuuming and the equipment I have:
    I use a pole with a vacuum head attached to it and obviously a hose. I have an inground pool with a Hayward sand filter.
    First off I put the vacuum head in the water with the hose attached. I then fill the hose up with water using the jet. When all the air is out I quickly put the end of the hose into the hole below the skimmer basket. So everything seems to be going good and I start to vacuum the bottom of the pool and I notice dirt or debris shooting back into the pool from the water jets. I do leave the the dial on the filter in the "filter" setting right? I have backwashed and it still doesn't seem to help. I also just put new sand in about a month ago. Any help would be appreciated.
    Thanks
    Hayward sand filter & super pump, Pool is weird shape but rough figures are 23x10x4.5 for a volume of 7800 gallons. Fiberglass shell
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Vacuuming trouble
    Any chance you could have cracked something while you were changing sand? Even a hairline crack, barely visible to the naked eye, can open up under pressure.
    Other than that, I'm out of ideas.
    Mooresville, NC
    32
    I'll double check but I haven't noticed any water leaking out anywhere. I had a friend that works on pools help me and I know we were very careful. Who knows though we might have. Thanks
    Kes's Avatar
    Apr 2010
    Worcester UK
    46
    Is there any reason why you can't vacuum to waste? After vacuuming, a few seconds on rinse and then back to filter. (Before I found TFP I was unaware of the practice of vacuuming through the filter.)
    11,000 Imp galls inground hopper 15' x 35', Delifol liner (vinyl), sand filter, Abrisud Classic cover, Palintest 315C test kit
    Quote Originally Posted by Kes
    Lose a lot of water doing this every time. I typically only vacuum to waste at the beginning of the year or if something went bad wrong, which hasn't happened since going BBB
    If you cracked a lateral inside the filter, you won't see a visible leak outside the filter canister.
    Jun 2010
    San Antonio
    424
    I had the same problem early this year. I was told by my pool repair guy that a sand filter will not catch the small particles, particularly when it is clean. So, I vacuumed to waste. I find that if I do not backwash before I vacuum I get a better result. YMMV
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Can't believe that no one else mentioned this...
    Get a skim-vac plate for the skimmer, leave the basket in place and line it with a skimmer sock when you vacuum.
    Luv& Luk
    -Ted
    Mooresville, NC
    32
    Great idea. I will be looking into this, this weekend. thanks!
