Thread: Whisperflo pump differences
    Jul 2009
    Olney, MD
    218
    Does anyone know if a WF-23 has the same pump as a WFE-3 with the difference being the motors? Curious if you upgrade a WF-23 with a B2980, would it then be basically a WFE-3?
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Whisperflo pump differences
    There are a couple of differences. First the WFE series use more efficient motors than the WF series, about 12% more efficient. Second, the WFE-3 is a full rated 3/4 HP pump while the WF-23 is an uprated 3/4 HP pump (1/2 HP full rated equivalent) so they aren't really the same pump. The WFE-3 is really the same pump as the WFE-24 and the WF-23 is the same as the WF-2.
    Also, upsizing the motor doesn't change the pump. The pump head curve is determined by the impeller not by the motor. The motor is simply appropriately sized to the impeller so it doesn't over heat and fail prematurely.
    Mark
