Thread: Maximum water level for a vinyl pool
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Hi All,
    One week ago (during a major 100+ deg heat wave), I was adding water daily, now we have had 3 days of rain.
    One of those rain events dumped 5.67" of rain.
    I have already dumped water once (to bring the water level to the middle of the skimmers.)
    Today, after more rain, the pool water level is again above the top of the skimmer window frame.
    The water is still ~2" below the liner bead.
    I HATE DUMPING WATER (especially in the middle of July.)
    My questions:
    How safely can I let my water rise?
    What could happen if I let it rise above the top of the liner (the bead where it fits into the slot)?
    Note, I know my skimmers are not doing much now with the water so high... but I HATE DUMPING WATER!
    *Edit to fix spelling error
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Maximum water level for a vinyl pool
    Your skimmers body has to parts and sometimes they aren't sealed together so water can leak out once it gets to the collar. I don't think I've seen a pools water get past the bead. If the water got past the bead it would probably seep slowly behind the liner. You don't want that. Just waste the water or give your system a good backwashing. Vacuuming on waste will give you better suction too
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Sounds like if you get another rain, it's gonna dump itself! I would err on the side of good filtration ans skimming and controlling where that "extra" water is gonna go.
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    I just did, 4 days ago, when the water level was just as high.
    I guess I'll dump it again...
    I just know when I dump this water, we will be in for another heat wave and I will have to add water again
    South Central NJ
    3,192
    A greater concern should be the water table. If it's high and starts to flow, the more water in the pool, the less likely the liner will become unseated and float out of position.
    Scott
    Owner of - PoolGuyNJ LLC
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Actually, I am not to worried about the water table (or the liner floating). I live on top of a hill, pretty much the highest point in the neighborhood. Additionally, my soil is very rocky and drains water like a strainer. Also, there was never any water in the pool hole (when it was under construction)... and that hole was open for a year befie they finished the pool.
