Thread: Burnt pump?
    Jul 2009
    Kingsville, TX
    8
    Burnt pump?
    Greetings:
    I just got back from a vacation of eleven days. While we were gone, I turned off my skimmers and set the pump to run about four hours each night. On our return, the breaker to the pump had been tripped and our friend who was watching the house said there were no electrical problems until today (when my pump breaker goes, so does the air conditioner on that side of the house, though that's another issue). When I reset the breaker and switched the pump on, there was a brief flash and puff of smoke from the back end of the pump where the electric cables come in, and the breaker threw again. Not wanting to cause further damage, I switched the pump off and left it as is. I'm mystified: there is still water in the pump, so I don't think it ran dry at any point; I regularly run the pump much more than four hours per day without trouble. If you have thoughts as to the cause (a timer "off" switch that magically stopped working during vacation?), or as to what my next steps should be (do I need to replace the pump, get the motor rebuilt, call an electrician?), I would greatly appreciate it.
    18/20x40 free form in ground 30,000 gal gunite sand filter, 1.5 hp pump with antique Polaris cleaner
    30,402
    Re: Burnt pump?
    Yes. It sounds like you have some electrical issuesw above and beyond most DIY folks.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Burnt pump?
    Assuming no other electrical problem outside the motor (get an electrician or at least someone handy with electrical stuff to check it out) , one option you don't mention is replacing the pump motor, you don't mention brand or model of the pump though. I recently had to replace a motor on a 1.5 HP hayward super pump, I bought the replacement from Pool Plaza based out of Dallas. Just thought I would mention this since you are in TX, and they were very fast shipping, I ordered at 2:30 pm one afternoon and motor arrived the next morning.
    Ike
    p.s. it is possible this is nothing more than vibration over time cutting into the insulation on the electrical wire and it shorting to ground against the motor frame.
