Thread: Cloudy Pool
    Jul 2010
    Charleston, WV
    2
    Cloudy Pool
    A month ago I switched from Bacquil to chlorine and it has worked great. Very glad I stumbled on this site.I followed the instructions closely in my conversion. I've changed my sand and have not shocked the pool in 2 weeks. I've purchased a test kit and have been checking the water almost once a day. The only issue I have is the water is still a little cloudy. I can see the bottom, but it's not clear. It has never gotten crystal clear. Here are my readings:
    FC - 5.5
    CC - .5
    PH - 7.5
    T/A - 70
    CH - 230
    CYA - 30
    Anyone have any idea what I need to do next?
    WMR 15x30x52" vinyl, AG pool with Hayward sand filter (100#)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cloudy Pool
    You could try a little DE in the sand filter, or a clarifier...sometime dirty sand filters better.
    Did it ever go clear during your conversion? Did the FC hold overnight before you changed the sand? (this is unusual for the water to not go clear but have the FC hold...)
    Lastly, how often are you running the filter? (Also I'm wondering if the filter is a little small for the pool)
    Jul 2010
    Charleston, WV
    2
    Re: Cloudy Pool
    Quote Originally Posted by frustratedpoolmom
    When I changed my sand last week it was clean, but I changed it anyway.The last couple of weeks it's been in the mid 90's here. Would the temperature be a factor?
    There was a lot of algae in the pool when I started this so I thought it might be dead algae but it should have filtered out or settled to the bottom by now, right?
    Yes the FC held overnight(for around 3 nights) before I changed the sand. I'm running the filter 2/7. How can I determine if the filter is the right size. It's the one that came with the pool (but I guess that doesn't mean anything does it) Looks like some research coming up.
    I'll add some clarifier and let you know how it turns out.
    By the way this is a great site!!!
