Results 1 to 7 of 7
Thread: Best Salt Test Kit?
    Central Connecticut
    159
    Best Salt Test Kit?
    I have read that many salt tests have a large range. I may be converting soon to an SWG system.
    What is the most accurate salt test kit recommended to buy?
    Thanks
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Best Salt Test Kit?
    The aquachek test strips are considered good.
    Check out this link.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    22,539
    And for another option, the Taylor drop based salt test is one of the better ones. The K-1766. It's available from Tftestkits as well as several places around the web.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    If you do convert to salt, definitely test your fill water first!
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by svenpup
    Going to have to disagree here. They read very high, and are not that accurate. Quite a few people here have said the same thing.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    AquaChek test strips have been absolutely perfect every time I have tried them. I'm on my seventh tube now and cross check each tube with the salt meter in my AutoPilot and the Taylor drop test and they are always spot on. That said, several other people have been having problems, so clearly they are not reliable enough to really depend on them. But I wouldn't say that they read high, because mine never do, but rather that they are not reliable in all situations and may read high or may not.
    Dec 2009
    2,690
    I would say they read high, since thats my experience, YMMV of course.
