Results 1 to 8 of 8
Thread: Help with balancing after new plaster
    Jul 2010
    Reno, Nevada
    22
    My 25K in-ground pool was re-plastered with Pebble Fina last Friday, and I'm having trouble balancing the water. Plus I saw in one topic here that a freshly plastered pool might require different recommended levels? At any rate my first obstacle is the high PH. I've added 1.5 gallons of muriatic acid over the course of the last several days, and PH is still off the chart. (I used the 'green' muriatic acid first, and now I'm using the nasty full-strength stuff.) Tough to gauge how much more to put in when every reading is too high to measure. Any suggestions?
    Next I'm going to need some CYA for this weekend's pool party, but I see that the solid should be added when back-flushing isn't necessary. But my fresh plaster requires constant brushing and back-flushing. How do I get around those conflicting requirements?
    At first reading my TA was 60, and I was going to boost that once I get PH under control. Calcium is also low - about 50 - so I was going to start adding that too. I've been using a combination of bleach and tri-chlor tablets for chlorination - partly to get the CYA up a little with the tablets because the pool is exposed to direct sunlight much of the day.
    Any advice appreciated.
    25K gal gunite pool with Auto Cover and Meyco mesh winter cover. Pump and filter in underground vault below level of returns. New Pebble Fina plaster in 7/2010.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Help with balancing after new plaster
    Quote Originally Posted by unsrek1
    Figure how much you need to get from max for your test to target, and repeat as necessary. Don't worry if it seems like you are adding too much. Its isn't like all this acid is "building up" and causing "acid water". All the acid you add is offset by the high pH from the plaster.
    Add the CYA in an old sock in front of a return (as opposed to in the skimmer). This way you aren't losing as much when you backwash.
    From another post:
    With fresh plaster, you don't want to adjust the CH level for the first three or four weeks. PH, TA, and CH will all be rising rapidly during the first month. If you raise CH too early, it will go up further and end up too high.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    The easiest way to determine how much acid to add is to use the acid demand in a titration test kit. If you are using the K-2006 (the TF100 does not have it), you add acid demand drops into the pH solution and count the number of drops it took to get to the desired pH. The you look up how many drops vs the size of your pool and the manual will tell you how much muriatic acid to add. You should try to get this under control because a high pH is not good for the plaster especially a fresh, still curing one.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Jul 2010
    Reno, Nevada
    22
    Thanks for the rapid responses. Sounds like I should not mess with TA or Calcium for the time being as they will be rising by themselves as the plaster cures.
    I'll look into a titration test kit to determine my acid demand. Would it be easier, better, safer to use dry acid from the pool store rather than muriatic acid since I may be doing this a lot for a while?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    ...Would it be easier, better, safer to use dry acid from the pool store rather than muriatic acid since I may be doing this a lot for a while?
    Easier-maybe, better-nope, safer-maybe. Dry acid adds sulpher, which you don't really want, and is more expensive.
    Muriatic acid is fine, as long as you take a little precaution. Wear eye protection when you use it. Pour slowly in front of a return with the pump on, or better yet dilute it into a 5 gallon pail 3/4 full of water before adding it to the pool (also in front of a return with the pump on).
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Always add acid to water; never add water to acid.
    Jul 2010
    Reno, Nevada
    22
    How about if I put the sock with the CYA in it into the debris net on my Polaris sweep? The acid wouldn't damage the net, would it? (Just haven't figured out the logistics of hanging a sock in front of a return.)
    Apr 2010
    Fleming Island, FL
    431
    Never thought about that, I think it is a great idea.
    Carlos
