Thread: Ballast/Balance tank over filling
    Jul 2010
    7
    Hi Guys
    I wonder if anyone can help me.
    I have moved into a villa with an overflow pool. The problem im having is that unless i shut the main drain valve, the balance tankballast tank overfills way past the ball **** auto fill. if i shut the main drain it levels out correctly.
    Any help would be greatly appreciated
    Regards
    Andy
    Re: Ballast/Balance tank over filling
    Welcome to TFP!
    Those symptoms suggest that there is a check valve somewhere between the main drain and the ballast tank that is not working correctly.
