- Jun 7, 2010
- 42
Hi,
I am newbie and just had liner replaced. I have also ordered refill to testkit thru TFT.
Now we are refilling the empty pool with tap water via hose. It will probably be filled by Friday to start the sand filter.
Question:
1. What do I need to prep and have ready from chemical balancing point of view? Considering it's fresh water, I hope do not need to much chemical in the begining.
If somebody could help me with different water tests and chemical balancing that I need to do before starting using the pool, I would appreciate it.
I am planning to do following tests once the water is filled:
FC, CC, TA, CYA & PH.
Question:
