Results 1 to 14 of 14
Thread: Too much salt in pool
    Pool just over a month old and just now finally starting up Intellichlor. Had been using chlorine pucks for first month. Chemical levels were tested and fine yesterday. SO I added 680lbs of salt yesterday per the PB's instructions and started up the Intellichlor at 40%. Flow is fine but my light is flashing on the Intellichlor stating at have too much salt. Not sure how much but the light means more than 4200ppm. Is this normal on the initial add of salt? Will it eventually go down and there is nothing that needs to be done or do I need to do something?
    24,000 gal free form with slide feature
    3.5ft to 5.5ft Sport Pool
    Midnight Blue Diamond Brite
    Intellichlor IC-40
    Intelliflow VS-3050
    Easy Touch 4
    Clean and Clear Cartridge
    Dec 2009
    Central Massachusetts
    2,690
    Re: Too much salt in pool
    What's the easytouch panel say it is? Go to diagnostics, then intellichlor. It will give you the salt reading.
    When you add any type of chemical, add about 3/4 of what is called for, then test the levels. Add the rest as needed. That way you dont over dose.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    22,468
    680 lbs of salt will raise the salt level in a 24,000 gal pool 3385ppm. It takes salt about 24hours or more to completely dissolve and thouroughly mix in the water. I'd give it a while and see if it settles down.
    DaveNJ's Avatar
    Toms River, NJ
    520
    According to the pool calc. for your size pool it would of raised the salt level by 3380ppm. I would wait for a couple of turn overs of water and see what it says.
    Beat me to it "BR".
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    The Easytouch says 4600ppm. Salt has been in for about 15 hours. Will it go down that much in 24 hours?
    Intellichlor IC-40
    Intelliflow VS-3050
    Easy Touch 4
    DaveNJ's Avatar
    Toms River, NJ
    520
    At least 24 hrs, depending on how long and what speed you run your pump.
    Dec 2009
    2,690
    Quote Originally Posted by wahoowa
    My experience with my IC-40, probably not, but you never know. Usually, it takes a while for the salt level readings to go UP on the Easytouch, not down, but YMMV.
    As a side note, i've found the pool calculator to be a little inaccurate for salt (sorry Jason)
    Also, your pool could be a bit smaller than you think, and the salt reading could be +/- 400 ppm different than what it actually is. As long as the cell light is green when it is supposed to be on and making chlorine, it is fine. The salt level will go down over time with splash out and top off.
    Okay, I will let it run for a couple days, We have been getting some decent rain today so I would assume that will help also dilute it. I was just concerned that level would be bad for the equipment and needed to do something more drastic.
    Intellichlor IC-40
    Intelliflow VS-3050
    Easy Touch 4
    Vero Beach, FL
    462
    Quote Originally Posted by bk406
    How so? I find it is right on. I've verified the ppm suggestions and they seem accurate. Probably, your ability to measure salt accurately is off. Test strips and SWG readouts are not very accurate. I used a refractometer from work to verify I was in the +/- 100 ppm range.
    There could be a small amount of salt in your fill water, and other chemicals can add salt to your water over time.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Dec 2009
    2,690
    You may be right on the salt water readout. I just find the pool calulator be to be off for me with salt; comes up high. Everything else is spot on though (TA, acid/base, FC, etc). Fill watwer has no salt, at least not any a tewst strip will read.
    In the end , it doesnt matter what anything else says except what the SWG says. The reading on the IC-40 is what matters. That dictates if it will work or not work.
    Just as an update, I am about 30 hours into it now. Last night, the Easy Touch read 4280ppm and the IC40 light was not blinking (steady green). This morning I am back to 4600ppm and the blinking green light is back on.
    Intellichlor IC-40
    Intelliflow VS-3050
    Easy Touch 4
    Dec 2009
    2,690
    Dont worry about it. The salt meter on the easy touch doesnt actually measure "salt". It measures conductivity of the water. Several factors go into that like salt levels, of course, but also water temperature, etc. The error can be as much as 400-500 ppm. For example, mine measures between 3400 and 3900 depending on when the sensor reads the conductivity. You just overdosed the salt a bit.
    If I truly did overdose, and it stays in the 4000+ ppm range, should I drain and add water or just let it run it's course and I won't need to add anything for a while :P
    Don't want to damage any equipment and do have new diamond brite plaster.
    Intellichlor IC-40
    Intelliflow VS-3050
    Easy Touch 4
    Dec 2009
    2,690
    Your IC-40 should be ok. Cant tell you about the plaster for certain,, but it should be ok too
