Results 1 to 7 of 7
Thread: Zinc Sacrificial Anode
    Aug 2008
    Honolulu
    429
    I noticed in this recent post:
    http://www.troublefreepool.com/conce...ng-t24345.html
    That the writer suggested adding a zinc sacrificial anode to help protect the pool from rust. Would this also help a pool such as mine from airborne iron depositing itself on the gunite surfaces, or is the airborne iron already oxidized? And would the Zinc cause stains?
    Thank you
    10,000 gal plaster pool,3/4 hp WhisperFlo pump, Sta-Rite Great White GW9500 pool cleaner, Hayward 300 lb Sand Filter
    Use Magenta Stuff for Iron and Silica control.
    Balance: pH 7.7 Cl 7 -8 Alk 70-80 CH 325 CyA 30 in winter - 50 in summer NaCl 1010 TDS 1200
    Re: Zinc Sacrificial Anode
    Nope, completely unrelated concepts.
    Aug 2008
    Honolulu
    429
    JasonLion,
    Thank you. Well there goes another crazy idea.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    To actually get rid of metals you can try using the metal trap product hooked up to a submersible pump to filter metals out of the water
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by X-PertPool
    I just bougfht one. I still need to do some more testing with it before i report on it, but lets just say at thisp point, i'm less that impressed.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Does it have a list of what metals it says it traps?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Dec 2009
    2,690
    Iron and copper. I mayh have my expectations set too high. Like i said, i need a few more tests before i draw any conclusions for sure.
