Thread: Should I replace the broken chorinator or not?
    Hi
    I am new to the forum and I love the BBB concept. I read the basics.
    My chlorinator is currently broke (plastic near connector is broke), should I replace it with a new chlorinator (~$100 in Lesiles). I have about half bucket of chlorine tablets that I had bought last year.
    Please advise, if it's worth buying chlorinator and is it useful if start using BBB approach.
    Thanks!
    33,000 gallon (20x40), Sand, IG, Vinyl
    Guest
    Re: Should I replace the broken chorinator or not?
    Chuck it and make the switch to bleach (chlorine) in liquid form. You'll be adding water, chlorine and a little bit of salt; nothing more! Once you've made the leap, and don't have to deal with all the junk in the pucks, you'll be glad you did
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    I just had my tab chlorinator removed. The line was replumbed I got a liquidator to auto feed liquid chlorine/bleach.
    I've noticed a few things...
    1. The jet pressure on my return is fantastic now as the tab feeder was allowing air into the pressure side of my system.
    2. Jug dumping was fine, but auto liquid feeding allows me even less hands on maintenance of my pool, which means more time for swimming and having fun.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Thank you! I will have the chlorinator outlet closed. I am ordering my refills thru TFT online too.
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    +1 for the Liquidator, best money I've spent on my pool in a long time. There is a forum here that will answer any questions you have about it.
    Also check out simicrintz's web page as he sells the liquidator and has great customer service...
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    X-PertPool's Avatar
    Exeter, PA
    1,385
    You can use your pucks in the skimmer to use them up. Just don't leave them in there with the system off.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
