Thread: New accurate beginning
    OK guys and gals...got my TF-100 the other day, but couldn't test since it was raining.
    Rained quite a bit yesterday too. Didn't rain today and got out late this afternoon and
    tested. Pump had been running since 11am. Tested at 5:30pm. Water temp was 90.
    Pool water is crystal clear.
    FC - 2.5
    CC - 0 remained clear after adding R-0003
    pH - 7.8
    TA - 150
    CH - 0 remained clear after adding R-0011L
    CYA - 20
    Anything look out of wack? Any test you think I should repeat?
    21,450 gallons from the spec sheet
    Sta-Rite System 3 Cartridge filter model S8M150, Max Flow 125 gpm, Filter area 450 sq ft
    IG 18X37 Grecian shaped vinyl pool, Pentair IntelliChlor IC40 chlorine generator
    Pentair 1.5 hp Challenger pump 130gpm, Pentair 3/4 hp booster pump 95gpm
    Located in Griffin, GA (about 30 miles south of Atlanta)
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: New accurate beginning
    When you did the CH test did you add the 20 drops of R-0010 before the 5 drops of R-0011L? It is very unlikely that it is 0. While low (no) CH is fine for a vinyl pool I question the validity of the test.
    Unless this is an indoor pool, CYA is very low for SWCG. You should target 70-80. Once you get the CYA up you should target FC at 5 or 6.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Yes...I did add the 20 drops of R-0010 before the R-0011L. But I will test again tomorrow since it's raining again.
    The low CYA doesn't surprise me. Not sure if any stabilizer was added or how much. Pool has only been in operation
    since the first week of June when constuction ended.
