Results 1 to 12 of 12
Thread: All chemicals in check except acid
    Nov 2009
    Sacramento
    57
    Pool looks good, I have the test kit I bought from TFP and everything except for my acid level is checking out good. I've been adding about 3/4 of a gallon a week for the past 3 weeks. Yesterday, I added a whole gallon around 6pm, then today I checked it and it's still in the dark purple range of 7.8 to 8.0. My buddy has a similar sized pool (both are salt water if that matters) and he only adds about 1/2 gallon a week. Any ideas on what could be going on? Thank you!
    Re: All chemicals in check except acid
    post a full set of test results please
    Nov 2009
    Sacramento
    57
    You got it. I have them written down at home and will do it tonight.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Sounds like your pH is really high, and you haven't added enough to get it down.
    Nov 2009
    Sacramento
    57
    That's what I thought, but the local pool store said adding 3/4 gallons for 2 weeks then 1 gallon the next week and testing the following day should have lowered the PH by now. Just didn't want to keep adding it if there's something else going on.
    We could give you a much better answer with a full set of water test results. Chances are your TA is really high, which is driving up the PH, but that is just guessing without knowing your actual numbers.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    When I took over the chemicals from the pool service last winter, I was astonished at how much acid I had to add. It took a 10 lb pail of dry acid and another gallon of liquid acid to get the color to change on the test block. And then even more to get it in range. Then there was all the aeration from the spa combined with our brutally hard water in California to use up some more.
    It's very similar to doing a drop test, really. You add and add and add and no change then it starts to move and seems like it takes forever, then one magic drop and it all changes at once.
    Nov 2009
    Sacramento
    57
    Here are my test results:
    FC 1.5
    CC 0
    TC 1.5
    pH 8.2 (looked a little higher)
    T/A 170
    CH 270
    CYA 60
    Thanks again.
    Your TA level is high, and was presumably much higher before. High TA levels tend to cause the PH to rise, the higher the TA level the faster the PH will rise. Once you get TA down the rate of PH increase will slow dramatically. You should take a look at the How To Lower Total Alkalinity article in Pool School.
    Nov 2009
    Sacramento
    57
    Thank you.
    22,542
    Doesn't really have anything to do with pH but your FC is pretty low even for a SWCG. You're asking fo trouble if it stays that low for long.
    Your TA is definitely a problem. If you have water features that aerate the water, that could be a contributor as well. Things like spa spillovers, waterfalls, and bubblers all cause the pH to rise.
