Thread: Test Lit Question
    Jul 2010
    Indianapolis, IN
    3
    Test Lit Question
    Since I have a Leslie's in my town, I would like to get a test kit there rather than wait for a TF-100 to be sent (I have an algae problem and need to get CL up to 25). The only problem is it appears the Leslie's DPD kit only measures CL up to 5 ppm. Am I looking at the wrong kit -- do they have one that measures CL at higher levels? Or should I wait for a TF-100? If I should wait, is there a way to measure CL up until that time?
    Thanks for the help!
    Jun 2008
    Wichita, KS
    22
    Re: Test Lit Question
    I would personally wait to get the TF-100, but if you choose not to and get a Taylor kit at Leslie's, you can dilute the water sample by 5:1 with water you know does not have chlorine in it. That may be a bit tricky without a graduated cylinder (you get 2 in the TF-100 ) but just getting in the ballpark should be fine as you don't need to be exact with chlorine.
    10k gal. IG vinyl, 1 hp pump, 200 lb sand filter, solar panels & cover
    22,550
    The kit you're looking at is the K-2005. You need either the K-2006 or the TF-100 kit. You'll never be happy with the K-2005. I'd personally order the TF-100 and wait for it.
    As the poster above said you can dilute the pool water sample with chlorine free water but past 4 parts it gets too inaccurate to be useful.
