Results 1 to 7 of 7
Thread: Intelliflo Owners - Hear a Soft Squeak on Start/Stop ?
    Jun 2010
    Fremont, CA
    293
    Intelliflo Owners,
    I installed my Intelliflo VF last week, and I hear a very soft "squeak" noise immediately on start, and about 1/2 second after I push stop (probably when the pump stops spinning). It sounds a bit like coming from middle of pump, but hard to tell for sure. Sounds a bit like a plastic squeak, like the pump controller plastic cover, but that's not it.
    Just wondered if other Intelliflo owners heard this. It's pretty soft, you can definitely hear it when you listen at start and stop of pump.
    Contacted Pentair via their pump blog, and one other recent Intelliflo owner and poster also remembered hearing a squeak, although he has to check to identify where it is coming from, the pump or a nearby Jandy valve. Pentair is checking with their engineers.
    Thanks for any input,
    Jeff
    40 x 16 (28k gallon) plaster pool, Intelliflo VF pump, Hayward 48 sq. ft. DE filter, using Purifiber, using BBB, TF-100 test kit
    Nov 2009
    Indialantic, FL
    323
    Re: Intelliflo Owners - Hear a Soft Squeak on Start/Stop ?
    Comparing noises over the Internet...but I think I have the same on a VS-3050 (which is the same pump except for controller module).
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    BobinBaltimore's Avatar
    Dec 2009
    Northeast of Baltimore, MD
    116
    Haven't noticed any squeaking on my VS-3050, but I will listen carefully when I am next down there.
    25' x 37' freeform, 22,000 gallon saltwater, 3'6" to 6'6" deep, including baja shelf and benches, 120 ft EP Henry retaining wall
    Pentair equipment (CC420 cartridge filter, VS-3050 variable speed pump, IC 60 salt cell, EasyTouch), 200 sq ft pool house
    View our Pool Build - View our Pool House Build
    Jun 2010
    Fremont, CA
    293
    After checking with engineers, Pentair tech said this soft squeak noise is normal on start/stop.
    In fact, he listened to two year old Intelliflo and heard it last night.
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by ride525
    Intelliflo tech said this soft squeak noise is normal on start/stop, after checking with engineers.
    Glad to hear that. I haven't heard the noise from my VF but I haven't been listening specifically for it. When I shut the pump on/off, at the pump's control panel, I'm under the deck, leaning over it, with my head about 24" from the pump. I have pretty good hearing. It may be normal but I'll bet not all of them do it. I will, though, listen more carefully, when I'm next down there.
    Thanks for the detective work.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    I get that with my new whisperflo.
    22,542
    It's common to hear a noise on most VFD motors as they start especially during soft start mode, which is most likely programmed into VS pumps.
